Unable to add/save custom columns for catalog
arthur.webware
Post by arthur.webware » 21 Aug 2024, 12:00
I have encountered an issue while trying to add new fields to the catalog. I used a migration and was able to create new fields using aimeos:setup. However, the problem arises when I need to use, display, and save values for these fields.
According to the documentation https://aimeos.org/docs/2024.x/models/extend-managers/, the "Custom way" approach didn't work for me. The example provided is either incomplete or specific to products.
I couldn't find a description of what Node is. Could you please describe it or provide a link to what it is?
Nevertheless, I was partially able to figure it out and add the necessary code to display values from the database. But the last issue I face is saving the new values.
I am receiving the following error:
SQLSTATE[08P01]: <<Unknown error>>: 7 ERROR:  bind message supplies 4 parameters, but prepared statement "" requires 7:
				UPDATE "mshop_catalog"
				SET "label" = ?, "code" = ?, "status" = ?, "mainactive" = ?, "mainorder" = ?, "sortorder" = ?
				WHERE "siteid" = '1.' AND "id" = ?
			["new catalog label","new_catalog",1,"40"]
#0 /app/vendor/aimeos/aimeos-core/src/MW/Tree/Manager/DBNestedSet.php(459): Aimeos\Base\DB\Statement\DBAL\Prepared->execute()
#1 /app/packages/ultra/src/MShop/Catalog/Manager/Ustandard.php(523): Aimeos\MW\Tree\Manager\DBNestedSet->saveNode(Object(Aimeos\MW\Tree\Node\Standard))
#2 /app/vendor/aimeos/aimeos-core/src/MShop/Common/Manager/Base.php(212): Aimeos\MShop\Catalog\Manager\Ustandard->saveItem(Object(Aimeos\MShop\Catalog\Item\Ustandard), true)
#3 /app/vendor/aimeos/aimeos-core/src/MShop/Catalog/Manager/Standard.php(611): Aimeos\MShop\Common\Manager\Base->save(Object(Aimeos\MShop\Catalog\Item\Ustandard), true)
#4 /app/packages/ultra/src/MShop/Catalog/Manager/Ustandard.php(498): Aimeos\MShop\Catalog\Manager\Standard->save(Object(Aimeos\MShop\Catalog\Item\Ustandard), true)
#5 /app/vendor/aimeos/aimeos-core/src/MShop/Common/Manager/Decorator/Base.php(240): Aimeos\MShop\Catalog\Manager\Ustandard->save(Object(Aimeos\MShop\Catalog\Item\Ustandard), true)
#6 /app/vendor/aimeos/aimeos-core/src/MShop/Common/Manager/Decorator/Base.php(240): Aimeos\MShop\Common\Manager\Decorator\Base->save(Object(Aimeos\MShop\Catalog\Item\Ustandard), true)
#7 /app/vendor/aimeos/ai-admin-jqadm/src/Admin/JQAdm/Catalog/Standard.php(242): Aimeos\MShop\Common\Manager\Decorator\Base->save(Object(Aimeos\MShop\Catalog\Item\Ustandard))
#8 /app/vendor/aimeos/ai-admin-jqadm/src/Admin/JQAdm/Common/Decorator/Base.php(151): Aimeos\Admin\JQAdm\Catalog\Standard->save()
#9 /app/vendor/aimeos/aimeos-laravel/src/Controller/JqadmController.php(219): Aimeos\Admin\JQAdm\Common\Decorator\Base->save()
, which occurs in the file /app/vendor/aimeos/aimeos-core/src/MW/Tree/Manager/DBNestedSet.php(459).
Here is the relevant code snippet:
	 * Stores the values of the given node to the storage.
	 * This method does only store values like the node label but doesn't change
	 * the tree layout by adding, moving or deleting nodes.
	 * @param \Aimeos\MW\Tree\Node\Iface $node Tree node object
	 * @return \Aimeos\MW\Tree\Node\Iface Updated node item
	public function saveNode( \Aimeos\MW\Tree\Node\Iface $node ) : \Aimeos\MW\Tree\Node\Iface
		if( $node->getId() === null ) {
			throw new \Aimeos\MW\Tree\Exception( sprintf( 'Unable to save newly created nodes, use insert method instead' ) );
		if( $node->isModified() === false ) {
			return $node;
		$stmt = $this->conn->create( $this->config['update'] );
		$stmt->bind( 1, $node->getLabel(), \Aimeos\Base\DB\Statement\Base::PARAM_STR );
		$stmt->bind( 2, $node->getCode(), \Aimeos\Base\DB\Statement\Base::PARAM_STR );
		$stmt->bind( 3, $node->getStatus(), \Aimeos\Base\DB\Statement\Base::PARAM_INT );
		$stmt->bind( 4, $node->getId(), \Aimeos\Base\DB\Statement\Base::PARAM_INT );
		$stmt->execute()->finish();
		return $node;
Could you please advise on how I can extend this method with three new fields without modifying the existing class?
Aimeos 2024 and Laravel11 from composer, Linux Ubuntu, PHP 8.2
Re: Unable to add/save custom columns for catalog
Post by aimeos » 22 Aug 2024, 10:21
The the easy way by creating a decorator for the catalog manager:
https://aimeos.org/docs/2024.x/models/e ... /#easy-way
The custom way works too but you have to extend the catalog standard manager class and overwrite the methods you need (updateUsage() for example).
arthur.webware
Post by arthur.webware » 23 Aug 2024, 06:21
Thank you for your response. I spent a lot of time re-reading the documentation over and over again. My goal was to use insert instead of insert-usage for updates, and similarly for updates. However, it turned out that to achieve this, I had to inherit from a large number of dependencies, including extending interfaces. This path seemed too complex (especially in the case of the catalog).
After your message, I decided to start from scratch. However, instead of fully reverting to the original position, I rolled back the changes in reverse order and, out of curiosity, added a decorator as well. The final code ended up as follows:
Create a migration for the new fields.
Then create/update the configuration file of your extension mshop.php, where you need to specify the name of the future decorator and the name of the future manager.
Create a decorator following the example from the documentation.
Create a manager also following the example from the documentation, but extend it with the createItemBase method, where in the return function, you replace \Aimeos\MShop\Catalog\Item\Standard with your own ItemStandard class, which you will create later.
Create a subclass of \Aimeos\MShop\Catalog\Item\Standard based on the documentation example, but instead of $this->myvalues, you should refer to $this->node->customvalue.
You can copy the admin panel template for the catalog into your extension and modify the code to manage the fields there. Here's an example:
<div class="form-group row optional advanced">
    <label class="col-sm-4 form-control-label help"><?= $enc->html($this->translate('admin', 'Main Order')) ?></label>
    <div class="col-sm-8">
        <input class="form-control item-label" type="number" tabindex="1"
               name="<?= $this->formparam(array('item', 'catalog.mainorder')) ?>"
               placeholder="<?= $enc->attr($this->translate('admin', 'Order in main page')) ?>"
               value="<?= $enc->attr($this->get('itemData/catalog.mainorder')) ?>">
    </div>
    <div class="col-sm-12 form-text text-muted help-text">
        <?= $enc->html($this->translate('admin', 'Order to show on main page')) ?>
    </div>
</div>
Migration
return array(
	'table' => array(
		'mshop_catalog' => function( \Aimeos\Upscheme\Schema\Table $table ) {
            $table->smallint( 'mainactive' )->default( 0 );
            $table->smallint( 'mainorder' )->default( 0 );
            $table->smallint( 'sortorder' )->default( 0 );
Decorator
<?php
namespace Aimeos\MShop\Catalog\Manager\Decorator;
use Aimeos\MShop\Catalog\Manager\Decorator\Base;
 * Manager decorator for Catalog
 * @see https://aimeos.org/docs/2024.x/models/extend-managers/#easy-way
class Udecorator extends Base
    private $attr = [
        'mainactive' => [
            'code' => 'catalog.mainactive',
            'internalcode' => 'mcat."mainactive"',
            'label' => 'Show on Main Page',
            'type' => 'int',
        'mainorder' => [
            'code' => 'catalog.mainorder',
            'internalcode' => 'mcat."mainorder"',
            'label' => 'Main Page Order',
            'type' => 'int',
        'sortorder' => [
            'code' => 'catalog.sortorder',
            'internalcode' => 'mcat."sortorder"',
            'label' => 'Sort Order',
            'type' => 'int',
     * @return array
    public function getSaveAttributes(): array
        return parent::getSaveAttributes() + $this->createAttributes($this->attr);
     * @param bool $withsub
     * @return array|\Aimeos\Base\Criteria\Attribute\Iface[]
    public function getSearchAttributes(bool $withsub = true): array
        return parent::getSearchAttributes($withsub) + $this->createAttributes($this->attr);
Manager
<?php
namespace Aimeos\MShop\Catalog\Manager;
use Aimeos\MShop\Catalog\Manager\Standard;
use Aimeos\MShop\Catalog\Exception;
class Ustandard extends Standard
    private array $customSearchConfig = array(
        'id' => array(
            'code' => 'catalog.id',
            'internalcode' => 'mcat."id"',
            'label' => 'ID',
            'type' => 'int',
            'public' => false,
        'catalog.siteid' => array(
            'code' => 'catalog.siteid',
            'internalcode' => 'mcat."siteid"',
            'label' => 'Site ID',
            'type' => 'string',
            'public' => false,
        'parentid' => array(
            'code' => 'catalog.parentid',
            'internalcode' => 'mcat."parentid"',
            'label' => 'Parent ID',
            'type' => 'int',
            'public' => false,
        'level' => array(
            'code' => 'catalog.level',
            'internalcode' => 'mcat."level"',
            'label' => 'Tree level',
            'type' => 'int',
            'public' => false,
        'left' => array(
            'code' => 'catalog.left',
            'internalcode' => 'mcat."nleft"',
            'label' => 'Left value',
            'type' => 'int',
            'public' => false,
        'right' => array(
            'code' => 'catalog.right',
            'internalcode' => 'mcat."nright"',
            'label' => 'Right value',
            'type' => 'int',
            'public' => false,
        'label' => array(
            'code' => 'catalog.label',
            'internalcode' => 'mcat."label"',
            'label' => 'Label',
            'type' => 'string',
        'code' => array(
            'code' => 'catalog.code',
            'internalcode' => 'mcat."code"',
            'label' => 'Code',
            'type' => 'string',
        'status' => array(
            'code' => 'catalog.status',
            'internalcode' => 'mcat."status"',
            'label' => 'Status',
            'type' => 'int',
        'catalog.url' => array(
            'code' => 'catalog.url',
            'internalcode' => 'mcat."url"',
            'label' => 'URL segment',
            'type' => 'string',
        'catalog.target' => array(
            'code' => 'catalog.target',
            'internalcode' => 'mcat."target"',
            'label' => 'URL target',
            'type' => 'string',
        'catalog.config' => array(
            'code' => 'catalog.config',
            'internalcode' => 'mcat."config"',
            'label' => 'Config',
            'type' => 'json',
            'public' => false,
        'catalog.ctime' => array(
            'label' => 'Create date/time',
            'code' => 'catalog.ctime',
            'internalcode' => 'mcat."ctime"',
            'type' => 'datetime',
            'public' => false,
        'catalog.mtime' => array(
            'label' => 'Modify date/time',
            'code' => 'catalog.mtime',
            'internalcode' => 'mcat."mtime"',
            'public' => false,
        'catalog.editor' => array(
            'code' => 'catalog.editor',
            'internalcode' => 'mcat."editor"',
            'label' => 'Editor',
            'type' => 'string',
            'public' => false,
        'catalog:has' => array(
            'code' => 'catalog:has()',
            'internalcode' => ':site AND :key AND mcatli."id"',
            'internaldeps' => ['LEFT JOIN "mshop_catalog_list" AS mcatli ON ( mcatli."parentid" = mcat."id" )'],
            'label' => 'Catalog has list item, parameter(<domain>[,<list type>[,<reference ID>)]]',
            'type' => 'null',
            'public' => false,
        'sort:catalog:position' => array(
            'code' => 'sort:catalog:position',
            'label' => 'Category position',
            'type' => 'int',
            'public' => false,
        'catalog.mainactive' => array(
            'label' => 'Main Active',
            'type' => 'int',
        'catalog.mainorder' => array(
            'label' => 'Main Order',
            'type' => 'int',
        'catalog.sortorder' => array(
            'type' => 'int',
    private \Aimeos\Base\DB\Connection\Iface $conn;
    public function __construct(\Aimeos\MShop\ContextIface $context)
        parent::__construct($context);
     * Returns the attributes that can be used for searching.
     * @param bool $withsub Return also attributes of sub-managers if true
     * @return \Aimeos\Base\Criteria\Attribute\Iface[] List of search attribute items
        return parent::getSearchAttributes($withsub) + $this->createAttributes($this->customSearchConfig);
     * Creates a new catalog item.
     * @param array $values
     * @param array $listItems
     * @param array $refItems
     * @param array $children
     * @param \Aimeos\MW\Tree\Node\Iface|null $node
     * @return \Aimeos\MShop\Common\Item\Iface
     * @throws Exception
    protected function createItemBase(
        array                      $values = [],
        array                      $listItems = [],
        array                      $refItems = [],
        array                      $children = [],
        \Aimeos\MW\Tree\Node\Iface $node = null
    ): \Aimeos\MShop\Common\Item\Iface
        if ($node === null) {
            if (!isset($values['siteid'])) {
                throw new Exception('No site ID available for creating a catalog item');
            $node = $this->createTreeManager($values['siteid'])->createNode();
            $node->siteid = $values['siteid'];
        if (isset($node->config) && ($values['config'] = json_decode($config = $node->config, true)) === null) {
            $values['config'] = [];
        return new \Aimeos\MShop\Catalog\Item\Ustandard($node, $values, $children, $listItems, $refItems);
Item
<?php
namespace Aimeos\MShop\Catalog\Item;
 * Generic interface for catalog items.
 * @package MShop
 * @subpackage Catalog
        \Aimeos\MW\Tree\Node\Iface $node,
        array                      $values = [],
        parent::__construct($node, $values, $children, $listItems, $refItems);
        $this->node = $node;
     * @return int
    public function getSortOrder(): int
        return (int)$this->node->sortorder;
     * @param int|null $value
     * @return Iface
    public function setSortOrder(?int $value): \Aimeos\MShop\Catalog\Item\Iface
        $this->node->sortorder = (int)$value;
        return $this;
     * @return int
    public function getMainOrder(): int
        return (int)$this->node->mainorder;
     * @return Iface
    public function setMainOrder(?int $value): \Aimeos\MShop\Catalog\Item\Iface
        $this->node->mainorder = (int)$value;
        return $this;
     * @return int
    public function getMainActive(): int
        return (int)$this->node->mainactive;
     * @return Iface
    public function setMainActive(?int $value): \Aimeos\MShop\Catalog\Item\Iface
        $this->node->mainactive = (int)$value;
        return $this;
     *  Sets the item values from the given array and removes that entries from the list.
     * @param array &$list Associative list of item keys and their values.
     * @param bool $private True to set private properties too, false for public only.
     * @return \Aimeos\MShop\Common\Item\Iface Catalog item for chaining method calls.
    public function fromArray(array &$list, bool $private = false): \Aimeos\MShop\Common\Item\Iface
        $item = parent::fromArray($list, $private);
        foreach ($list as $key => $value) {
            switch ($key) {
                case 'catalog.sortorder':
                    $item = $item->setSortOrder($value);
                    break;
                case 'catalog.mainorder':
                    $item = $item->setMainOrder($value);
                    break;
                case 'catalog.mainactive':
                    $item = $item->setMainActive($value);
                    break;
                default:
                    continue 2;
            unset($list[$key]);
        return $item;
     * Returns the public values of the node as array.
     * @param bool $private True to return private properties, false for public only.
     * @return array Associative list of key/value pairs.
    public function toArray(bool $private = false): array
        $list = parent::toArray($private);
        $list['catalog.sortorder'] = $this->getSortOrder();
        $list['catalog.mainorder'] = $this->getMainOrder();
        $list['catalog.mainactive'] = $this->getMainActive();
        return $list;
mshop.php
<?php
 * @license LGPLv3, https://opensource.org/licenses/LGPL-3.0
 * @copyright Aimeos (aimeos.org), 2015-2024
return array(
    'catalog' => array(
        'manager' => array(
            'decorators' => array(
                'local' => array('Udecorator'),
            'name' => 'Ustandard',
            'lists' => array(
                'type' => array(
                    'delete' => array(
                        'ansi' => '
						DELETE FROM "mshop_catalog_list_type"
						WHERE :cond AND "siteid" LIKE ?
                    'insert' => array(
                        'ansi' => '
						INSERT INTO "mshop_catalog_list_type" ( :names
							"code", "domain", "label", "i18n", "pos", "status",
							"mtime","editor", "siteid", "ctime"
						) VALUES ( :values
                    'update' => array(
                        'ansi' => '
						UPDATE "mshop_catalog_list_type"
						SET :names
							"code" = ?, "domain" = ?, "label" = ?, "i18n" = ?,
							"pos" = ?, "status" = ?, "mtime" = ?, "editor" = ?
						WHERE "siteid" LIKE ? AND "id" = ?
                    'search' => array(
                        'ansi' => '
						SELECT :columns
						FROM "mshop_catalog_list_type" mcatlity
						:joins
						WHERE :cond
						ORDER BY :order
						OFFSET :start ROWS FETCH NEXT :size ROWS ONLY
                        'mysql' => '
						SELECT :columns
						:joins
						WHERE :cond
						ORDER BY :order
						LIMIT :size OFFSET :start
                    'count' => array(
                        'ansi' => '
						SELECT COUNT(*) AS "count"
						FROM (
							SELECT mcatlity."id"
							:joins
							WHERE :cond
							ORDER BY mcatlity."id"
							OFFSET 0 ROWS FETCH NEXT 10000 ROWS ONLY
						) AS list
                        'mysql' => '
						FROM (
							:joins
							WHERE :cond
							LIMIT 10000 OFFSET 0
						) AS list
                    'newid' => array(
                        'db2' => 'SELECT IDENTITY_VAL_LOCAL()',
                        'mysql' => 'SELECT LAST_INSERT_ID()',
                        'oracle' => 'SELECT mshop_catalog_list_type_seq.CURRVAL FROM DUAL',
                        'pgsql' => 'SELECT lastval()',
                        'sqlite' => 'SELECT last_insert_rowid()',
                        'sqlsrv' => 'SELECT @@IDENTITY',
                        'sqlanywhere' => 'SELECT @@IDENTITY',
            'cleanup' => array(
                'ansi' => '
				DELETE FROM "mshop_catalog"
				WHERE :siteid AND "nleft" >= ? AND "nright" <= ?
            'delete' => array(
                'ansi' => '
				WHERE "siteid" = :siteid AND "nleft" >= ? AND "nright" <= ?
            'get' => array(
                'ansi' => '
				SELECT :columns
					mcat."id", mcat."code", mcat."url", mcat."label", mcat."config",
					mcat."status", mcat."level", mcat."parentid", mcat."siteid",
					mcat."nleft" AS "left", mcat."nright" AS "right",
					mcat."mtime", mcat."editor", mcat."ctime", mcat."target",
					mcat."sortorder"
				FROM "mshop_catalog" mcat, "mshop_catalog" AS parent
				WHERE parent."id" = ?
					AND mcat."siteid" = :siteid
					AND parent."siteid" = :siteid
					AND mcat."nleft" >= parent."nleft"
					AND mcat."nleft" <= parent."nright"
					AND mcat."level" <= parent."level" + ?
					AND :cond
				GROUP BY :columns
					mcat."nleft", mcat."nright", mcat."target",
				ORDER BY mcat."nleft"
            'insert' => array(
                'ansi' => '
				INSERT INTO "mshop_catalog" (
					"siteid", "label", "code", "status", "parentid", "level",
					"nleft", "nright", "config", "mtime", "ctime", "editor", "target"
				) VALUES (
					:siteid, ?, ?, ?, ?, ?, ?, ?, \'\', \'1970-01-01 00:00:00\', \'1970-01-01 00:00:00\', \'\', \'\'
            'insert-usage' => array(
                'ansi' => '
				SET :names "url" = ?, "config" = ?, "mtime" = ?, "editor" = ?, "target" = ?, "ctime" = ?
            'update' => array(
                'ansi' => '
				WHERE "siteid" = :siteid AND "id" = ?
            'update-parentid' => array(
                'ansi' => '
				SET "parentid" = ?
            'update-usage' => array(
                'ansi' => '
            'move-left' => array(
                'ansi' => '
				SET "nleft" = "nleft" + ?, "level" = "level" + ?
				WHERE "siteid" = :siteid AND "nleft" >= ? AND "nleft" <= ?
            'move-right' => array(
                'ansi' => '
				SET "nright" = "nright" + ?
				WHERE "siteid" = :siteid AND "nright" >= ? AND "nright" <= ?
            'search' => array(
                'ansi' => '
				SELECT :columns
					mcat."mainactive", mcat."sortorder", mcat."mainorder"
				WHERE mcat."siteid" = :siteid AND mcat."nleft" >= ?
					AND mcat."nright" <= ? AND :cond
				ORDER BY :order
            'search-item' => array(
                'ansi' => '
				SELECT :columns,
				:joins
				WHERE :cond
				GROUP BY :group
				ORDER BY :order
                'mysql' => '
				SELECT :columns,
				:joins
				WHERE :cond
				GROUP BY :group
				ORDER BY :order
            'count' => array(
                'ansi' => '
				FROM (
					SELECT mcat."id"
					:joins
					WHERE :cond
					GROUP BY mcat."id"
					ORDER BY mcat."id"
				) AS list
                'mysql' => '
				FROM (
					SELECT mcat."id"
					:joins
					WHERE :cond
					GROUP BY mcat."id"
					ORDER BY mcat."id"
				) AS list
            'newid' => array(
                'oracle' => 'SELECT mshop_catalog_seq.CURRVAL FROM DUAL',
            'lock' => array(
                'db2' => 'LOCK TABLE "mshop_catalog" IN EXCLUSIVE MODE',
                'mysql' => "DO GET_LOCK('aimeos.catalog', -1)", // LOCK TABLE implicit commits transactions
                'oracle' => 'LOCK TABLE "mshop_catalog" IN EXCLUSIVE MODE',
                'pgsql' => 'SET TRANSACTION ISOLATION LEVEL SERIALIZABLE',
                'sqlanywhere' => 'LOCK TABLE "mshop_catalog" IN EXCLUSIVE MODE',
                'sqlsrv' => "EXEC sp_getapplock @Resource = 'aimeos.catalog', @LockMode = 'Exclusive'",
            'unlock' => array(
                'mysql' => "DO RELEASE_LOCK('aimeos.catalog')",
                'sqlsrv' => "EXEC sp_releaseapplock @Resource = 'aimeos.catalog'",
Yes, mshop.catalog.manager is copy of catalog.php config, but without this copying code does not work.
If you see mistake please reply here =)
Post by aimeos » 23 Aug 2024, 07:47
You don't need to copy the SQL statements, especially not for the sub-managers. What happens if you remove them from your config?
