new "save basket as template" feature
columbo
Post by columbo » 01 Sep 2024, 10:57
I'm looking for a "save basket as template" feature.
I know that baskets can already be saved at checkout, but I need more functionality:
  • manage multiple basket templates
  • edit saved baskets (remove or add product to template list)
  • on catalog- and product detail page: "add product to basket-template"-button, with a "template list" selector
What do you recommend for implementation?
Extend the favorites feature? Or any other suggestions?
Thank you!
Re: new "save basket as template" feature
Post by aimeos » 01 Sep 2024, 21:47
With the current "save basket" feature, you can save multiple baskets as templates and add the products to the current basket (later) again. It's currently not possible to edit saved baskets, only to apply them to the current (empty) basket, save them again and delete the old basket. Editing baskets feature can be add based on the current implementation I guess.
The "add to template" feature definitively needs some more customization but I would try to use a different basket type for the templates to avoid merging with the current basket.
columbo
Post by columbo » 18 Sep 2024, 08:04
I am trying to create a new, empty 'order/basket' with a custom name ($baskettemplateName).
It creates a new basket, but also fills it with products from my current frontend basket.
Because of: ->setItem( \Aimeos\Controller\Frontend::create( $context, 'basket' )->get()
$manager = \Aimeos\MShop::create( $context, 'order/basket' );
$item = $manager->create()->setId( md5( microtime( true ) . getmypid() . rand() ) )
	->setCustomerId( $userId )->setName( $baskettemplateName )
	->setItem( \Aimeos\Controller\Frontend::create( $context, 'basket' )->get() );
$manager->save( $item );
Tried with empty ->setItem() and also without ->setItem but its not working.
How can I create a new, empty 'order/basket' ?
Thank you!
Post by aimeos » 18 Sep 2024, 11:47
Create an empty basket/order using:
\Aimeos\MShop::create( $context, 'order' )->create()
columbo
Post by columbo » 20 Sep 2024, 08:13
unfortunately i'm still struggeling:
to create a new basket template:
       ->setName( $view->param( 'templatename') )
       ->setItem( \Aimeos\MShop::create( $context, 'order' )->create() );
add a product to a template:
//first get basket
$filter = $manager->filter()
       ->add( 'order.basket.customerid', '==', $context->user() )
       ->add( 'order.basket.id', '==', $basketid );
$basketCntl = $manager->search( $filter )->getItem() ;
//add Product to basket
$product = \Aimeos\MShop::create($context, 'product')->get(	$prodid, ['text', 'media', 'price']);
$orderProduct = \Aimeos\MShop::create($context, 'order/product')->create();
$orderProduct->copyFrom($product);
$basketCntl->addProduct($orderProduct, 1);
get all basket templates and their products
$filter = $manager->filter()->order( '-order.basket.mtime' )
	->add( 'order.basket.name', '!=', '' );
$view->basketItems = $manager->search( $filter );
I did not receive any errors, but the product is not added to the basket template
thank you
Post by aimeos » 22 Sep 2024, 21:11
Without saving the basket after you've added the product, no changes will persist in the database.
columbo
Post by columbo » 23 Sep 2024, 21:06
but how?
tried with manager->save(), but
$manager->save( $basketCntl );
causes
Aimeos\MShop\Order\Manager\Basket\Standard::saveItem(): Argument #1 ($item) must be of type Aimeos\MShop\Order\Item\Basket\Iface, Aimeos\MShop\Order\Item\Standard given...
and
$manager->save( $orderProduct );
causes:
Aimeos\MShop\Order\Manager\Basket\Standard::saveItem(): Argument #1 ($item) must be of type Aimeos\MShop\Order\Item\Basket\Iface, Aimeos\MShop\Order\Item\Product\Standard given
I can't use the frontend controller (\Aimeos\Controller\Frontend::create( $context, 'basket' )) as the product should not be added to the (frontend) basket, only added to the template-basket
Post by aimeos » 24 Sep 2024, 09:27
$basket = $manager->search( $filter )->first();
if($item = $basket->getItem())
	$orderProduct = \Aimeos\MShop::create($context, 'order/product')->create()->copyFrom($product);
	$item->addProduct($orderProduct, 1);
	// save basket again
	$manager->save($basket);
columbo
Post by columbo » 27 Sep 2024, 08:38
Unfortunately it doesn't work - the orderProduct is not saved to the basket.
Then loading order/basket again, right after $manager->save($basket) the product is missing
    Log::info("item 1:" . print_r(json_encode($item), true));
//test output
$manager2 = \Aimeos\MShop::create( $context, 'order/basket' );
$filter2 = $manager2->filter()
$basket2 = $manager2->search( $filter2 )->first();
if($item2 = $basket2->getItem())
    Log::info("item 2:" . print_r(json_encode($item2), true));
output:
item 1:{"order.siteid":"1.","coupons":[],"products":{"1":{"order.product.siteid":"1.","cgroups":0,"order.product.prodcode":"25025","order.product.productid":"101794","order.product.type":"default","order.product.scale":1,"order.product.target":"","order.product.name":"Product ABC","order.product.mediaurl":"..."}},"services":[],"addresses":[],"price":{...},"locale":{...},"customer":null}
item 2:{"order.siteid":"1.","coupons":[],"products":[],"services":[],"addresses":[],"price":{...},"locale":{...},"customer":null}
Post by aimeos » 27 Sep 2024, 09:14
This is a working example from an unit test for Aimeos 2024.x:
$product = \Aimeos\MShop::create( $context, 'product' )->find( 'CNE' );
$orderProduct = \Aimeos\MShop::create( $context, 'order/product' )->create()->copyFrom( $product );
$order = \Aimeos\MShop::create( $context, 'order' )->create()->addProduct( $orderProduct );
$basket = $manager->save( $manager->create()->setItem( $order )->setId( 'test-1' ) );
$basket2 = $manager->get( $basket->getId() );
