Adding custom parameters to jobs command
MaHo
Post by MaHo » 27 Sep 2024, 11:33
Laravel: v11.21.0
AImeos: 2024.07.2
PHP: 8.3.0
OS: Ubuntu 22.04.5
I want to add some custom parameters to my jobs command for debugging, after some research and some trying i cannot find how to do this, is this at all possible?
For some context: i want to create a job that exports all orders to my clients administration software. To do some debug i would like to have te option to disable the actual file upload and be able to change the date range for the orders i want to export. In laravel i would do something like:
php artisan app:collect-orders {--date=} {--upload=true}
Is there something like this in the aimeos job interface? or do i have to create a laravel command, splitting my cronjobs over 2 standards and file locations?
Re: Adding custom parameters to jobs command
Post by aimeos » 27 Sep 2024, 11:43
The Artisan aimeos:jobs command currently doesn't support passing arbitrary options to the Aimeos job controllers. One possibility would be to add an "--option" parameter like the aimeos:setup command supports to set custom configuration:
https://github.com/aimeos/aimeos-larave ... nd.php#L30
MaHo
Post by MaHo » 27 Sep 2024, 12:31
I will look into it, thank you!
Post by aimeos » 27 Sep 2024, 12:34
We will add that possibility to 2024.10 LTS :-)
