How to confgigure base.blade.php in new theme extension
AleksandarJovanovic
Post by AleksandarJovanovic » 02 Oct 2024, 07:35
Php 8.2
Linux
Version 2024.07.
Hello everyone, I could use a little help.
I installed the theme extension according to the instructions, and everything is fine. However, the <base.blade.php> file located in resources/view/vendor/shop controls the settings for both the default theme and this new one. How can I create a new base.blade.php file that will be called and control things in the new theme I want to assign to a new vendor in the multishop?
Thanks in advance,
Alex
Re: How to confgigure base.blade.php in new theme extension
Post by aimeos » 02 Oct 2024, 07:58
Place the base.blade.php file for the new theme in ./resources/view/vendor/<custom extension name>/base.blade.php
AleksandarJovanovic
Post by AleksandarJovanovic » 02 Oct 2024, 13:40
Hm. I try that first but not working for me. I try to clear cache both for aimeos and laravel but nothing happen. :(
AleksandarJovanovic
Post by AleksandarJovanovic » 03 Oct 2024, 08:01
The mistake was mine, thank you for your patience :)
I didn’t extend the new base.blade in the template. Maybe this will help someone else too.
Best regards.
