Sitemap export multishop same site code in all store
AleksandarJovanovic
Post by AleksandarJovanovic » 04 Oct 2024, 07:15
Php 8.2
Linux
Version 2024.07.
I have a small problem with the sitemap export. In all the sitemaps, it shows all products, but they all have the URL of the default shop:
I am running the following commands:
php artisan aimeos:jobs product/export/sitemap default
php artisan aimeos:jobs product/export/sitemap demo
The result in the URL is the same local shop name.
Default:
<?xml version="1.0" encoding="UTF-8"?>
<urlset xmlns="http://www.sitemaps.org/schemas/sitemap/0.9">
<url><loc>http://localhost:8000/default/shop/defaullt-proizvod</loc><lastmod>2024-10-03T21:46:32+00:00</lastmod></url>
</urlset>
Demo:
<url><loc>http://localhost:8000/default/shop/patike-rmfashionlookaaaaaaa</loc><lastmod>2024-10-03T20:31:29+00:00</lastmod></url>
<url><loc>http://localhost:8000/default/shop/job-csv-test-selection</loc><lastmod>2024-10-03T14:28:48+00:00</lastmod></url>
<url><loc>http://localhost:8000/default/shop/proba-123</loc><lastmod>2024-10-03T14:31:00+00:00</lastmod></url>
</urlset>
I found the whole code in sitemap-item.php, but everything seems fine there.
Thanks in advance.
Re: Sitemap export multishop same site code in all store
Post by aimeos » 04 Oct 2024, 14:43
This is currently a problem when you create the sitemaps for each site one by one and we will fix that in the next release. To get correct URLs for all site, export all sitemaps at once please:
AleksandarJovanovic
Post by AleksandarJovanovic » 04 Oct 2024, 15:46
I try, in that case is generete all sitemaps which is ok but the same problem exist. The url of all sitemap is on default shop.
Post by aimeos » 04 Oct 2024, 15:49
The problem is this if-condition:
https://github.com/aimeos/ai-controller ... ms.php#L43
If it's removed, it works as expected.
AleksandarJovanovic
Post by AleksandarJovanovic » 04 Oct 2024, 15:54
It works:)
Thank you
