Open AI Error: 429
AleksandarJovanovic
Open AI Error: 429
Post by AleksandarJovanovic » 16 Oct 2024, 12:53
Php 8.2
Linux
Version 2024.10.
I tried to integrate the API with OpenAI and added the secret key to the .env file. I tested the key, and everything works fine. However, on Aimeos, it constantly returns an Error: 429. There is no error reported in the log. Could I get some help with this?
Thank you in advance.
Re: Open AI Error: 429
Post by aimeos » 16 Oct 2024, 13:04
Make sure you update the packages to the latest versions and you have aimeos/ai-admin-jqadm 2024.10.3 installed. Before, there was an error regarding OpenAI integration.
AleksandarJovanovic
Post by AleksandarJovanovic » 16 Oct 2024, 13:41
I update on last version but the error still exist.
"require": {
"php": "^8.1",
"composer-runtime-api": "^2.2",
"aimeos-extensions/backend": "dev-main",
"aimeos-extensions/frontend": "dev-main",
"aimeos-themes/bluetheme": "dev-main",
"aimeos/ai-admin-jqadm": "2024.10.3",
"aimeos/aimeos-laravel": "~2024.10",
"guzzlehttp/guzzle": "^7.2",
"laravel/breeze": "^2.0",
"laravel/framework": "^11.0",
"laravel/sanctum": "^4.0",
"laravel/tinker": "^2.9"
Post by aimeos » 16 Oct 2024, 13:47
Then, your quota has been reached if you are only using a free account:
https://help.openai.com/en/articles/689 ... r-requests
AleksandarJovanovic
Post by AleksandarJovanovic » 21 Oct 2024, 18:11
You were right, it was necessary to add the payment method, and now everything works perfectly. Maybe this answer will help someone else as well.
Best regards
