Problem with filters and supplier
AleksandarJovanovic
Post by AleksandarJovanovic » 17 Oct 2024, 21:34
Php 8.2
Linux
Version 2024.10.
Hello, it's me again :)
I came across a bug and tested it on version 2024.07.2, where everything works fine, and now on version .10, where I’m encountering a problem.
When the demo content is imported, everything works properly, including filters and suppliers, meaning you can filter products, and when you click on suppliers, it displays all suppliers as it should. However, when the products are deleted and you start adding your own products, neither the filters nor the supplier option work. I’ve tested it several times on freshly installed versions.
Could you check if it's the same on your end?
Best regards
Re: Problem with filters and supplier
Post by aimeos » 21 Oct 2024, 16:09
Thanks for your bug report :-)
We've fixed the problem in aimeos/ai-admin-jqadm 2024.10.x-dev. Can you check?
AleksandarJovanovic
Post by AleksandarJovanovic » 21 Oct 2024, 18:09
Thank you, Aimeos team :) It works perfectly now. Is there a way I can report any bugs I come across, without posting on the forum? I don't think I should send it here.
Best regards :)
Post by aimeos » 22 Oct 2024, 07:09
The best way for bug reports is to open an issue in the appropriate Github repository:
https://github.com/aimeos
