Can I create a design like www.stance.com without connecting to another front-end?
dungminh86
Hello, I have a question. The default Aimeos interface is quite decent, but as you may know, it could be polished to look even better. I really like the design of www.stance.com, so is it possible to build a similar design using just the Aimeos Laravel package? Or should I consider using Aimeos Headless to connect with other front-end platforms like Vue Storefront?
Re: Can I create a design like www.stance.com without connecting to another front-end?
The Berlin theme is very close to that web site esp. the filter in the catalog list view:
https://themes.demo.aimeos.org/en/berlin/shop/
The rest is just adapting the CSS a bit to create a more flat design.
