How to Import customer XML?
What is the difference between “User” and “Customer”?
How can I import existing customers?
I have the following packages/xxxx-theme/config/controller.php:
storage/import/customer/1/test.xml is the sample XML file from https://aimeos.org/docs/2024.x/cronjobs ... ml-import/
There are no errors, but no customers are imported either.
Aimeos: 2024.04.*
Laravel: 11.0
PHP: 8.2
return [
'jobs' => [
'customer' => [
'export' => [
'csv' => [
'location' => 'storage/export/customer'
'import' => [
'xml' => [
'location' => 'storage/import/customer/1/test.xml'
'order' => [
'export' => [
'csv' => [
'location' => 'storage/export/order'
'email' => [
'payment' => [
'pdf' => false
'delivery' => [
'pdf' => false
];There are no errors, but no customers are imported either.
Aimeos: 2024.04.*
Laravel: 11.0
PHP: 8.2
Re: How to Import customer XML?
The Laravel "users" table is used for the Aimeos customer domain when using Laravel. In Aimeos, we are always speaking about "customers".
Don't change the location if you don't need it because it's the path relative to the fs-import virtual filesystem which is mapped to ./storage/import/ in your installation. Then, place your customer XML file into the ./storage/import/customer/default/ directory and run the artisan command for importing the customer XML files:dburucu wrote: 02 Jan 2025, 00:33 How can I import existing customers?
php artisan aimeos:jobs customer/import/xmlUpgrade to 2024.10 LTS because earlier version are not supported any more and don't receive bugfixes and security updates.
