Installation problem
I am trying to install Aimeos in an existing Laravel application.
I am following the installation instructions given on https://github.com/aimeos/aimeos-laravel.
However, when I run
'composer update -W'
the script never completes when trying to do
'\Aimeos\Shop\Composer::join'
There are no errormessages, but the script just seems to 'hang'.
Any ideas how to fix this?
...or will the installation maybe still work fine without completing this step?
Thanks in advance for any help!
However, when I run
Re: Installation problem
Seems like you can't connect to Github for some reason. This step isn't strictly required for a working installation and you can remove the "\\Aimeos\\Shop\\Composer::join" line from the scripts section in your composer.json if the problem persists.
Thanks for the information; I will just skip this step then.aimeos wrote: 08 Mar 2025, 11:32 Seems like you can't connect to Github for some reason. This step isn't strictly required for a working installation and you can remove the "\\Aimeos\\Shop\\Composer::join" line from the scripts section in your composer.json if the problem persists.
...but, just out of curiosity, what does "\\Aimeos\\Shop\\Composer::join" actually do?
You get notified in your Github timeline about Aimeos related updates
