Add html in cms content in admin.
AleksandarJovanovic
Post by AleksandarJovanovic » 25 May 2025, 07:25
Laravel
- 2025
Hello, i have question how to add in cms (grapejs) Html block or mby h2,h3 text to be managed from admin panel.
Tnx
Re: Add html in cms content in admin.
Post by aimeos » 27 May 2025, 08:22
Headings are available in the list of elements you can enter in the CMS module.
If you want to insert HTML code directly, you need to create a content block like the existing ones:
https://github.com/aimeos/ai-cms-grapes ... om.js#L235
Also, you need to create a component for that content block:
https://github.com/aimeos/ai-cms-grapes ... om.js#L401
