Custom email queue backed by database
jafo66
Post by jafo66 » 06 Jun 2025, 15:19
Based on some business logic, I need to create an email queue backed by a database table. I've tried to follow what the AI chat gave me but I'm missing a key piece.
I created my database queue handler class in my extension: packages/mypackage/src/MQueue/Queue/DBQueue.php
namespace MQueue/Queue
In my config/shop.php, I have added the following:
'resource' => [
		... all the other standard stuff above this entry
		'queue' => [
			'mq-team' => [
				'standard' => [
					'class' => \MQueue\Queue\DBQueueTeam::class,
I'm using the following to read/write to the queue:
$queue = $context->queue('mq-team', 'team/coachassign');
$queue->get();
My 2 questions:
  1. How do I properly configure the queue to use database class noted above?
  2. What configuration do I need to add to enable the madmin_queue capabilities I see in: https://github.com/aimeos/aimeos-base/b ... andard.php
jafo66
Re: Custom email queue backed by database
Post by jafo66 » 06 Jun 2025, 15:33
On question #2, it looks like I just needed to modify the config/queue.php by changing the 'default' to be database. I will configure the .env file instead of making that hardcoded change just to confirm.
Is that the correct approach?
Post by aimeos » 06 Jun 2025, 20:52
Unfortunately, the AI in the chat often mixes up things it learned from other code bases but which isn't applicable in Aimeos :-/
Using DB based queues is really simple and all you need is explained here:
https://aimeos.org/docs/latest/infrastr ... age-queues
Add a message to a queue:
$queue = $this->context()
    ->queue( 'mq-email', 'order/email/payment' )
    ->add( json_encode( ['email' => 'me@example.com'] ) );
Get the messages in a job controller sending the emails:
$queue = $this->context()->queue( 'mq-email', 'order/email/payment' );
while( $msg = $queue->get() )
    $data = json_decode( $msg->getBody() );
    // perform the task
    $queue->del( $msg );
The "mq-email" is the key to the configuration of the queue manager if your have several queue services like DB, RabbitMQ, etc. and if it doesn't exist, it falls back to "mq" configuration defined in your ./config/shop.php. The "order/email/payment" is the name of the actual queue which you use and it can be any string. We use the path of the job controller to know easily know where the queue belongs to.
jafo66
Post by jafo66 » 06 Jun 2025, 23:15
How do I configure my own database backed class for a specific queue type ex: my-team?
It seemed like I just needed to add a configuration line item, is there something else much more difficult?
Thanks!
Post by aimeos » 07 Jun 2025, 10:07
Use this config for your own queue class:
'mq' => [
	'adapter' => 'DBQueueTeam',
	// implementation specific configuration
You can see how other queue adapters are implemented here: https://github.com/aimeos/ai-mqueue
