Problem with jsonapi product (with image)
bar_on
Post by bar_on » 03 Jul 2025, 06:32
Product with media (images) is not listed in the jsonapi/product?include=product.media API.
Not just the included media, but the product itself is also hidden.
I had a product without media that could be shown successfully, but not after I add the media.
Any ideas why this would happen? I did clear some tables (mshop_media) before this problem arises, due to loss of media storage, and was trying to remove all the media.
let url =
import.meta.env.VITE_SERVER_DOMAIN +
`/jsonapi/product?sort=${sortBy}&include=product.media,product.price,product.category,product,attribute`
API used.
Re: Problem with jsonapi product (with image)
Post by aimeos » 03 Jul 2025, 08:07
Guess, the problem is somewhere else. The product isn't returned by the JSON API most likely even if you add no "include" parameter at all. Can you check and see if this product is enabled and doesn't have any start/end time restrictions?
bar_on
Post by bar_on » 04 Jul 2025, 07:50
I've found out that if those products not showing does not have a category selected. Once I select a category it will show up in the API. Not sure if this is intended but it's good for now.
The version I'm using is aimeos 2023.10.9.
Post by aimeos » 04 Jul 2025, 09:21
Yes, that's the intended behavior. Products without a category assigned are not available in the frontend and are used e.g. as rebate products.
bar_on
Post by bar_on » 04 Jul 2025, 21:15
Got it, thanks!
