Adjust layout product detail
IOU42
Post by IOU42 » 09 Jul 2016, 08:02
With the shop installed I am trying to change the layout of the product detail page. I want the associated long description to be visible by default. Now it is hidden by default (display 'none', I believe triggered by java script 'toggle-js').
What is the best way to do this? Can it be done using the configuration when in the 'list item detail screen' of the long description?
Thanks!
System info:
Running Aimeos Laravel: 2022.10
Laravel Framework 9.52
Almalinux
PHP 8.1
Re: Adjust layout product detail
Post by aimeos » 09 Jul 2016, 11:57
The easiest way is to create a new extension for your project (https://aimeos.org/developer/extensions/), copy the template in question and adapt it to your needs.
IOU42
Post by IOU42 » 11 Jul 2016, 21:57
Thanks working well!
System info:
Almalinux
PHP 8.1
