Adding Multiple Attribute For a product
wassim.hattab
Post by wassim.hattab » 06 Sep 2016, 14:45
Hello i'm facing a problem when adding multiple attributes (color,length, options) when i choose them and click add to basket in the basket i only see the last attribute (options) and the other two attributes i chose is not showing
any idea?
Re: Adding Multiple Attribute For a product
Post by aimeos » 06 Sep 2016, 15:41
Maybe you've mixed variant and configurable attributes.
If you have a selection product with two or more articles (type "default"), the color/length attributes must be attached to the articles with list type "variant". If you only have one product (type "default") and want all attributes to be configurable and optional, then they need to be attached as "configurable" attributes to that product.
