Links at views going to root
				daniel.groppo
I'm beginner with Aimeos at Laravel 5.2. I have followed every step of installation documentation (including auth steps for Laravel 5.2). I already searched in many communities about my problem, but I'm no finding anything.
I'm using XAMPP with PHP 5.6 and my application is located at C:/xamp/htdocs/myapp/ - I modified the .env file to recognize the myapp folder (APP_URL=http://localhost/myapp). When I execute Request::root() its returns localhost/myapp/public (ok!).
When I type the address in the browser, it works perfectly (Example: localhost/myapp/public/list). But my problems are the Aimeos links. Example: when I click in one product item, it opens http://localhost/detail/1/Demo_article/0. The same occurs when I click anything else, like Basket (http://localhost/basket).
Am I doing anything wrong?
Re: Links at views going to root
Laravel requires your ./public/ directory to be the document root so http://localhost/ will return the Laravel welcome page. Then, the Aimeos links will work as expected.
									Professional support and custom implementation are available at  Aimeos.com
				daniel.groppo
Thanks for your reply, but is it possible to use Aimeos inside a subdirectory like 'myapp'? Its because I have many others Laravel applications inside the localhost (even these apps works well with subdirectory), and in the future I want to create others Aimeos app in my local server.
That's a good question. Aimeos doesn't make any assumptions about the URLs and leaves everything to the Laravel router. If you can convince the Laravel router to generate URLs which includes the subdirectories, it will work. Then you only have to adapt the directories for the Aimeos content in the config file.
You should be aware that there may be security problems if you store your Laravel application in a subdirectory because e.g. the log and session files are then available in public.
				daniel.groppo
Thank you again for your reply. I did not know about these security problems. I created a virtual host in my local environment and my problem was partially solved.
Now I can acess http://myapp/list and all the links are working. But when I login (http://myapp/admin), I'm redirected to http://myapp/jqadm/search/dashboard, and the following exception is displayed:
And when I type http://myappp/jqadm or http://myapp/extadm, the following exception is displayed:
I thought that these errors were due to the previously reported problem, but have not been resolved. Am I doing anything wrong again?
HttpException in Handler.php line 107:
This action is unauthorized.Code: Select all
NotFoundHttpException in RouteCollection.php line 161:Re: Links at views going to root
Did you create the user account with
If you only register users, they don't have access to the admin interface.
./artisan aimeos:account --admin you@example.comProfessional support and custom implementation are available at  Aimeos.com
				daniel.groppo
Yes, I executed the command, but I had the same problem of bruno: https://github.com/aimeos/aimeos-laravel/issues/62
The connection with database is working. I did the installation from the scratch again. I executed the following commands (without any error), but the mshop_customer_list_type have no records (others tables like products are ok).
And when I run the command that you mentioned, the register is created at users table and it returns:
How can I get around this?
Thank you for your patient, it is the first time I do it alone.
php artisan vendor:publish
 php artisan migrate
 php artisan aimeos:cache
 php artisan cache:clearCode: Select all
[Aimeos\MShop\Exception]
  No item found for conditions: Array
      [customer.lists.type.code] => default
      [customer.lists.type.domain] => customer/group
  )Thank you for your patient, it is the first time I do it alone.
You've said the "mshop_customer_list_type" table is empty. What about the "users_list_type"?
				daniel.groppo
Yes, there are 5 registers in users_list_types.
There should be six. I guess, the one with domain='customer/group' is missing?
