Error /list data: Locale item for site "default" not found
Hi I just installer aimeos using laravel 5.2, but when I try to browse the catalog list page:
http://127.0.0.1:8000/index.php/list
I am getting this error:
Exception in Standard.php line 518:
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
Re: Error /list data: Locale item for site "default" not fo
Your database doesn't contain some records for an unknown reason. You can execute
again to add the missing entries.
./artisan aimeos:setup --option=setup/default/demo:1
You get this error if the locale site entry is disabled. To enable it, go to the admin interface (expert mode) and change the status to "available" in the Locale -> Site tab.
Please how do i access the admin interface or the expert mode in order to chabge the statusaimeos wrote:You get this error if the locale site entry is disabled. To enable it, go to the admin interface (expert mode) and change the status to "available" in the Locale -> Site tab.
You need an admin account you can create with
php ./artisan aimeos:account --admin <email>
