Query about admin
AlexYoung31
Query about admin
Post by AlexYoung31 » 02 Oct 2016, 18:27
Where abouts are the queries to form the dashboard for admin. I.e if I wanted to make one for profits.
Re: Query about admin
Post by aimeos » 02 Oct 2016, 21:13
The dashboard uses the Aimeos JSON API to retrieve the data:
https://aimeos.org/docs/Developers/Admi ... arch_items
To group the filtered results (like a GROUP BY), use the additional parameter
aggregate=...
e.g.
aggregate=order.cdate
The "columns" you can search for and group by are the same as listed in the managers. You can use the "aggregate=..." parameter for every manager that has an aggregate() method, e.g. https://github.com/aimeos/aimeos-core/b ... andard.php
