Issue with DirectorySeparator in aimes-core (Bootstrap.php)
konsa054
Post by konsa054 » 13 Jan 2017, 12:46
There seems to be an issue with the DirectoryIterator in getManifests() method of the Bootstrap.php in the aimes-core.
As a result, directories are sorted randomly and in case there is an extension folder, it is not loaded correctly.
Could you take a look? There needs to be a way that directories are always returned in the same order and extensions are returned correctly. In my case I am overwriting templates in my extension.
Environment: Linux
PHP version: 5.6.21
Aimeos: aimeos/aimeos-laravel ~2016.10
Re: Issue with DirectorySeparator in aimes-core (Bootstrap.p
Post by aimeos » 13 Jan 2017, 13:07
What's the result of the problem in your case? Are the core templates used instead of your own?
If so, could you add 'ai-client-html' to the 'depends' section of the manifest.php in your own extension?
konsa054
Post by konsa054 » 13 Jan 2017, 13:17
Thank you !!! This resolved it.
You are quick as hell :D
Regards,
Konstantin
