Stripe Payment gateway not working
Re: Stripe Payment gateway not working
Can you please point me out what changed from your dev-master that made strip work? if you can point me to the actual git hub commits that changed would be great
It's this one: https://github.com/aimeos/ai-client-htm ... bd1a5aa866
Great, Thank you
does it work with Apple Pay?
Depends on the Omnipay Stripe driver. You can have a look and test it yourself:
https://github.com/thephpleague/omnipay-stripe
MikaelNazarenko
- Expert
Hi guys, I also have problems with Stripe.
My version:
Seems I have configured it properly, but in checkout I don't get a form where I would have to set card number and other.
I am trying it on my local machine, and on remote server I had the same. I got error at once as on screenshot:
My version:
aimeos/ai-laravel 2019.07.3 Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-payments 2019.07.3 Payment extension for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core 2019.07.11 Full-featured e-commerce components for high performance online shopsSeems I have configured it properly, but in checkout I don't get a form where I would have to set card number and other.
- Screenshot from 2019-09-28 12-14-14.png (25.85 KiB) Viewed 8615 times
MikaelNazarenko
- Expert
I took a look at /var/www/schmuck/ext/ai-payments/lib/custom/src/MShop/Service/Provider/Payment/Stripe.php and seems there are some fields which are missing in admin interface. Maybe this is why I don't get payment form when checkout ?
On the attachments is my stripe fields on the back-end
- Screenshot from 2019-09-28 13-53-47.png (26.78 KiB) Viewed 8602 times
MikaelNazarenko
- Expert
Seems I have figured out it. In console I got: (index):1 Uncaught IntegrationError: Live Stripe.js integrations must use HTTPS
But I have set testmode on my settings. Can I test it without https ?
