Offer file upload for customer - Possible
Re: Offer file upload for customer - Possible
Post by aimeos » 12 Dec 2020, 18:58
Uploaded files are not part of the $_POST variable but in $_FILES which you can access by $view->request()->getUploadedFiles()
bozo
Post by bozo » 13 Dec 2020, 16:22
you are right, it should be in $_FILES.
Sadly empty.
I think the my main problem is related to "Content-Type"
Basket checkout is always "application/x-www-form-urlencoded; charset=UTF-8".
For file upload it is must be "multipart/form-data;", otherwise it won't work.
I tried to change it in all possible ways, but no luck. It is still sending x-www-form.
Post by aimeos » 14 Dec 2020, 10:09
bozo
Post by bozo » 14 Dec 2020, 19:27
yes, I did.
Days later in my despair all possible places where "application/x-www-form-urlencoded" found.
no luck.
nos3
Post by nos3 » 15 Dec 2020, 18:14
Guess, the problem is the XHR request done instead of a normal POST by the browser:
https://github.com/aimeos/ai-client-htm ... s.js#L1284
This example code may help to implement a file upload using jQuery XHR:
https://makitweb.com/how-to-upload-imag ... ry/#jQuery
