How to change templates
kimholberg
Re: How to change templates
Post by kimholberg » 30 Oct 2017, 15:03
I placed the aimeos extension in Packages/Extension/ and called it ai-twelveinch
But i have deleted this now, because nothing works. After composer update (as you recommended in another subject) i got internal server 500 du to 'No composer manifest file found at "/opt/bitnami/apps/neos/htdocs/Packages/Extensions/ai-twelveinch/composer.json".'
I can see the manifest file so i am very confused.
Just about to give up on Aimeos as nothing seems to work for me - it looked promising, but after weeks of trial and errors i start thinking this is too difficult for me.
Neos 3.2.0 - Bitnami AWS C2 - Aimeos 2017-10.1
Post by aimeos » 30 Oct 2017, 15:09
The Flow framework is most probably the hardest one to use because the framework is very complex so integration isn't easy. Laravel is much easier for example and the Aimeos integration works well for many developers adapting it to their needs.
kimholberg
Post by kimholberg » 30 Oct 2017, 21:05
Hello Tom,
sorry but i have giving up, this is too difficult for me.
Thanks for your patience and support.
Regards,
Kim
