Checkout Process - Error on Summary Tab
Re: Checkout Process - Error on Summary Tab
The "aimeos_shop_privacy" route is defined by default if you didn't disable it (by accident):
https://github.com/aimeos/aimeos-larave ... #L252-L266
Check the "routes" section in your ./config/shop.php file and try to add this:
'legal' => [],
taimoorbadar
unfortunately still did not work. yes the shop terms and shop privacy routes are already there in package routes.php file. and i have added
'legal' => [],
in my config/shop.php in the routes section. i cleared the configuration and cache but still does not work. and i get the same error in my admin logs.
Route [aimeos_shop_privacy] not defined.
'legal' => [],
taimoorbadar
I am also started to get this error in my admin panel and no tab works, i can not open the catlog or anything else, only the dashboard page and logs page is being open but that also does not work propely
- Now i started to get this error on my admin panel
- Screenshot from 2021-10-08 01-02-50.png (128.37 KiB) Viewed 7774 times
Can you post a screenshot after you've clicked on the "js?locale=en:3547" link right of the error message?
