Catalog (Category) Import via Script
mohal_04
Re: Catalog (Category) Import via Script
Post by mohal_04 » 06 Jul 2018, 11:03
aimeos wrote:Like said, create a job controller that uses the managers to import an arbitrary format directly:
- https://aimeos.org/docs/Developers/Cont ... controller
- https://aimeos.org/api/latest/namespace ... MShop.html
I know you are trying your best to help me but the links you sent me are little bit advanced for me. Can you send few others links that help me understand basics first? I shall look into these links to understand how to implement managers.
Thanks!
Post by aimeos » 09 Jul 2018, 07:40
Here you can read how to work with managers to search and save items like products, attributes, texts, prices, etc. first:
https://aimeos.org/docs/Developers#Managers_and_items
mohal_04
Post by mohal_04 » 10 Jul 2018, 10:21
aimeos wrote:Here you can read how to work with managers to search and save items like products, attributes, texts, prices, etc. first:
I have another small question related to this same issue. Currently, all jobs are inside "ai-controller-jobs" extension that comes with Aimeos. So, I need to create my own job to import product then where should I add that in my extension? Because I don't have following kind of directory structure in my extension:
./ext/ai-controller-jobs/controller/jobs/src/Controller/Jobs
Plus, where would I configure my job to be run?
Please, reply!
Thanks!
Post by aimeos » 10 Jul 2018, 21:51
You should have:
./ext/myext/controller/jobs/src/
You can add the missing ./Controller/Jobs/ directories yourself. You job is executed by the artisan command, e.g. for
./ext/myext/controller/jobs/src/Product/Import/Myimport/Standard.php
run
php artisan aimeos:jobs product/import/myimport
