SYMFONY_ENV=prod composer update --no-dev
Seds
Re: SYMFONY_ENV=prod composer update --no-dev
Post by Seds » 17 Jul 2018, 20:58
OK
I pasted lines in /app/config/config.yml
Is it there i have to to do it?
because I didn't only change baseurl, I added all lines in configuration, they didn't exist already.
is it normal?
I made an update --no-dev
I changed / updated an image
made a cache:clear
url are ok now but image not appear in front
do you have some advices?
Post by aimeos » 17 Jul 2018, 21:52
Is the image shown if you paste the URL into a new browser window? What's the HTTP status returned?
Seds
Post by Seds » 19 Jul 2018, 17:55
first, I put in baseurl: localhost/shop/web to have a correct image url
then urls are good in source and when I past urls in browser images are shown
detail page:
source
			<figure id="image-0"
				class="item" style="background-image: url('localhost/shop/web/files/5/6/566771890afc8e950092ca8d5d054dc4.jpg')"
				itemprop="image" itemscope="" itemtype="http://schema.org/ImageObject"
				data-image="localhost/shop/web/preview/2/3/23ea5ee0e3e1e2d2789e0287dd2f9564.jpg"
				<a href="localhost/shop/web/files/5/6/566771890afc8e950092ca8d5d054dc4.jpg" itemprop="contentUrl"></a>
				<figcaption itemprop="caption description">product1.jpg</figcaption>
			</figure>
		<a class="social-button social-button-pinterest"
			href="https://pinterest.com/pin/create/button/?url=http%3A%2F%2Flocalhost%2Fshop%2Fweb%2Fdetail%2F1%2FLevi%2527s_501&description=Levi%27s_501&media=localhost%2Fshop%2Fweb%2Ffiles%2F5%2F6%2F566771890afc8e950092ca8d5d054dc4.jpg"
			title="pinterest"
			target="_blank"
		></a>
network:
Request URL: http://localhost/bundles/aimeosshop/themes/aimeos-detail.js
Request Method: GET
Status Code: 404 Not Found
Request URL: http://localhost/shop/web/detail/1/localhost/shop/web/preview/2/3/23ea5ee0e3e1e2d2789e0287dd2f9564.jpg
Request Method: GET
Request URL: http://localhost/shop/web/detail/1/localhost/shop/web/files/5/6/566771890afc8e950092ca8d5d054dc4.jpg
Request Method: GET
Request Method: GET
list page
source:
<div class="media-list">
		<noscript>
			<div class="media-item" style="background-image: url('localhost/shop/web/preview/2/3/23ea5ee0e3e1e2d2789e0287dd2f9564.jpg')" itemscope="" itemtype="http://schema.org/ImageObject">
				<meta itemprop="contentUrl" content="localhost/shop/web/preview/2/3/23ea5ee0e3e1e2d2789e0287dd2f9564.jpg" />
			</div>
		</noscript>
	<div class="media-item lazy-image" data-src="localhost/shop/web/preview/2/3/23ea5ee0e3e1e2d2789e0287dd2f9564.jpg"></div>
</div>
network:
Request URL: http://localhost/shop/web/localhost/shop/web/preview/2/3/23ea5ee0e3e1e2d2789e0287dd2f9564.jpg
Request Method: GET
list/1/XXX
source:
	<div class="catalog-stage-image">
	</div>
no error in network
but i have pictures in this category, one in stage type, an other in standard stage. and no trace of images in source
thanks
Post by aimeos » 21 Jul 2018, 08:07
The URL .../shop/web/ must be the document root of your vhost. Then, the images are shown correctly. Putting the your Symfony installation in a sub-directory doesn't work without adapting the configuration.
Furthermore, you should use "http://localhost/" so it's not interpreted as a directory by the browser.
Seds
Post by Seds » 25 Jul 2018, 18:34
Using http://localhost/ on detail :
Request Method: GET
Request URL: http://localhost/preview/2/3/23ea5ee0e3e1e2d2789e0287dd2f9564.jpg
Request Method: GET
Post by aimeos » 26 Jul 2018, 21:20
As long as the directory " ./<yourapplication>/web/" is not the document root of your virtual host, it won't work.
Seds
Post by Seds » 05 Aug 2018, 09:06
it's what i've done on #p6494 post
it doesn't work neither on url, or image display
Post by aimeos » 06 Aug 2018, 21:09
Is the file in ./<yourapplication>/web/bundles/aimeosshop/themes/aimeos-detail.js available on the command line?
Seds
Post by Seds » 07 Aug 2018, 10:04
i made an composer update, then on product page it works, image appears
but not on categories
yes file in ./<yourapplication>/web/bundles/aimeosshop/themes/aimeos-detail.js is available
no error anymore on command line
Post by aimeos » 08 Aug 2018, 07:27
Please clear the content cache which may still contain the wrong URLs:
./bin/console aimeos:cache
