Example pages
Re: Example pages
Post by aimeos » 29 Jan 2019, 06:43
"getRefItems()" is available in all items that implement the \Aimeos\MShop\Common\Item\ListRef\Iface interface, i.e. products, categories, attributes, customers, services, prices and texts.
"$item->price" and "$item->text" is undefined, you need to call
$priceItems = $item->getRefItems( 'price', 'default', 'default' );
$textItems = $item->getRefItems( 'text', 'long' );
Trent
Re: Example pages
Post by Trent » 29 Jan 2019, 14:19
I've tried using it as: {{$item->getRefItems('text', 'long')}}
But it returns "htmlspecialchars() expects parameter 1 to be string, array given"
I've tried intiallizing it in the controller and no luck either.
Re: Example pages
Post by aimeos » 31 Jan 2019, 12:50
returns an array of text items which you should output in a loop. This applies to all calls of getRefItems()
Trent
Re: Example pages
Post by Trent » 31 Jan 2019, 17:00
I've tried inserting it into a foreach loop but I still have problems. Would you be able to give me an example?
Re: Example pages
Post by aimeos » 02 Feb 2019, 19:59
@foreach ($item->getRefItems('text', 'long') as $text)
    <p>{{ $text->getContent() }}</p>
@endforeach
Trent
Re: Example pages
Post by Trent » 03 Feb 2019, 13:57
That works thank you! I didn't know about the getContent(). It isn't registering the <p><strong> tags for some reason though.
Is there a similar method to get the images to load? The getContent() doesn't seem to work for it.
Screenshot from 2019-02-03 13-54-57.png (17.33 KiB) Viewed 7056 times
Re: Example pages
Post by aimeos » 04 Feb 2019, 09:44
The "{{ ... }}" automatically escapes the tags. Blade offers a different syntax for unchanged output.
For images, you can use getUrl() or getPreview():
- https://aimeos.org/api/latest/class-Aim ... Iface.html
For the available methods in the different items, please have a look at the API docs:
https://aimeos.org/api/latest/namespace ... MShop.html
Trent
Re: Example pages
Post by Trent » 11 Feb 2019, 09:45
Cool beans! I managed to have a decent looking page now :)
Any chance you could tell me how to add the add to basket option on this? And where I can customize the nav bar?
Re: Example pages
Post by aimeos » 12 Feb 2019, 12:00
To show the "add to basket" button in the list view, you have to set this configuration option to "1" or true:
https://aimeos.org/docs/Configuration/C ... basket-add
Furthemore, your have to add the "domain" setting descripted in the documentation page.
This works for the standard template. If you created your own template, you have to adapt your template to the functionality of the standard template.
The navigation bar is defined in your app.blade.php template file and managed by Laravel so you have all options Laravel is offering there.
Trent
Re: Example pages
Post by Trent » 12 Feb 2019, 14:31
To make my own functionality do I just pass the five parameters to a separate function to make it work? Or is there an easier way to update the basket contents?
