Get Mini Basket With Product Images also
parmonov98
Re: Get Mini Basket With Product Images also
Post by parmonov98 » 12 Oct 2020, 12:41
aimeos wrote: 11 Oct 2020, 08:57 The parameters your can pass are described here:
https://aimeos.org/docs/latest/frontend ... ter-names/
any you didn't tell me what to pass in. What data does $this->link('client/html/catalog/lists/url', data) expect?
Please, tell me how the $this->links() work? where is it?
How can I see its implementation or detailed info for to use it in templates?
harshithvemula
Post by harshithvemula » 12 Oct 2020, 16:50
I have added the product image to the mini cart but it updates only after reloading the page. i have tried adding code to update basket function but it didn't worked .please help me. I have added this code
<img src="<?= $this->content( $product->getMediaUrl() ) ?>" />
AimeosBasketMini updateBasket function-
$(".thumbnail--container img", product).attr("src", entry.attributes['order.base.product.mediaUrl']);
Post by aimeos » 13 Oct 2020, 06:57
parmonov98 wrote: 12 Oct 2020, 12:41
It depends on the string you are passing to the link view helper:
- 'client/html/catalog/lists/url' e.g. ['f_catid' => 1]
- 'client/html/catalog/detail/url' e.g. [d_name => 'My-product']
The article describes all parameters which are accepted, their meaning and if they are required.
Post by aimeos » 13 Oct 2020, 07:01
harshithvemula wrote: 12 Oct 2020, 16:50 I have added the product image to the mini cart but it updates only after reloading the page. i have tried adding code to update basket function but it didn't worked .please help me. I have added this code
Guess, your CSS selector ".thumbnail--container img" is wrong and doesn't match the node you want to update.
parmonov98
Post by parmonov98 » 16 Oct 2020, 03:56
Waht am I doing wrong?
https://imgur.com/a/7oczeYq
https://i.imgur.com/UScMOcR.png ?
Post by aimeos » 16 Oct 2020, 15:52
There's no method named getUrl() for product items. Use this instead:
$product->getName( 'url' )
