Property-Based SKU
Re: Property-Based SKU
Maybe there's a problem in the JS code for the detail template:superscotty19 wrote: 2.) SKUs appearing in frontend: Ah yes! I set the stock, added to basket, and I see the SKU. However, the Manufacturer Part Number (MPN) Property that I defined is acting weird. When I click on the product, I see the "Properties" accordion but when I click it, *all* the MPN properties for all the variants appear. Even if I select a variant, the accordion still shows all MPNs. How can I make it so that I only see the MPN that applies to the selected variant?
- https://github.com/aimeos/ai-client-htm ... d.php#L449
- https://github.com/aimeos/ai-client-htm ... os.js#L667
Can you check that?
superscotty19
Good idea. The code viewer for the PHP file was cut off but I think that's the problem (specifically, around line 461. I say that because when I look at the source of my item detail page, it has the following code:
That's suspect because:
a.) The MPN for the variant I chose is in the code
b.) 14/20 items are missing the classes subpart and subproduct-x (or 6/20 have extra classes). Perhaps these 14/20 are the same as the 14/20 causing the initial save problem earlier?
c.) When I change a variant attribute variable using the dropdowns, nothing changes in the Properties dropdown on the page
I hope that gives some insight. I can investigate (b) a bit further by creating another selection product and monitoring the results. However, it won't have 20+ variants....
-S.
<tbody>
<tr class="item subproduct subproduct-33">
<td class="name">MPN</td>
<td class="value">90052014</td>
</tr>
<tr class="item subproduct subproduct-35">
<td class="value">90052024</td>
</tr>
<tr class="item subproduct subproduct-37">
<td class="value">90052012</td>
</tr>
<tr class="item subproduct subproduct-39">
<td class="value">90052013</td>
</tr>
<tr class="item subproduct subproduct-41">
<td class="value">90052714</td>
</tr>
<tr class="item subproduct subproduct-43 subproduct-actual">
<td class="value">90052715</td>
</tr>
<tr class="item">
<td class="value">90052716</td>
</tr>
<tr class="item">
<td class="value">90052717</td>
</tr>
<tr class="item">
<td class="value">90052032</td>
</tr>
<tr class="item">
<td class="value">90052033</td>
</tr>
<tr class="item">
<td class="value">90052734</td>
</tr>
<tr class="item">
<td class="value">90052735</td>
</tr>
<tr class="item">
<td class="value">90052736</td>
</tr>
<tr class="item">
<td class="value">90052737</td>
</tr>
<tr class="item">
<td class="value">90052022</td>
</tr>
<tr class="item">
<td class="value">90052023</td>
</tr>
<tr class="item">
<td class="value">90052724</td>
</tr>
<tr class="item">
<td class="value">90052725</td>
</tr>
<tr class="item">
<td class="value">90052726</td>
</tr>
<tr class="item">
<td class="value">90052727</td>
</tr>
</tbody>
-S.
superscotty19
Update to 3.) ... here are the steps I take to create a mess:
a.) Create product + variants
- Enter basic info, choose select
- enter variants (see screenshot 1)
- enter images
- enter text (long description)
- enter prices (0 tax, 689 actual)
- enter default category
- enter characteristics (attributes)
- click save and close
-> all products created as new products, variant attributes are saved to variant attributes
- enter mpn property for 1 item (see screenshot 2)
- save and close
b.) go to frontend
- mpn shows no matter what (see screenshot 3)
- choose a colour and it works but the size goes to a default (see screenshot 4)
- change colour to metallic and set new size - colour changes but size doesnt (see screenshot 5)
- no matter what colour i choose, it sticks on metallic black. in some cases, it changes the size but not the colour even - though i selected colour not size (see screenshot 6)
- if size is "please select" then i can change colour (see screenshot 7)
Looks like a glitch to me ....
- enter images
- save and close
b.) go to frontend
- aimeos select 3.png (238.88 KiB) Viewed 13348 times
- aimeos select 2.png (67.76 KiB) Viewed 13348 times
- aimeos select 1.png (161.79 KiB) Viewed 13348 times
superscotty19
more attachments...
- aimeos select 6.png (239.71 KiB) Viewed 13348 times
- aimeos select 5.png (240.03 KiB) Viewed 13348 times
- aimeos select 4.png (239.9 KiB) Viewed 13348 times
superscotty19
We can confirm that there's a problem with showing the right attributes and properties. Will come back to you when fixed.
Problem has been fixed with this commit: https://github.com/aimeos/ai-client-htm ... 1fe36a2a0b
It's also available in aimeos/ai-client-html version 2019.04.7 and 2018.10.20 and will be part of the next TYPO3 package uploaded to TER. If you don't use composer, you can add the changes of the template and JS file yourself in the meantime.
superscotty19
Hi, Sorry for the delay - had to fix wife's car
OK I copied/pasted the code to the 2 files, tested it and while it's better it is still glitching. Here's the scenario:
Item: Bike 1
Bike 1 color red, size small, part # (property) 90418-8002
Bike 1 color red , size large, part # (property) 90418-8004
Bike 1 color blue, size small, part # (property) 90418-8102
Bike 1 color blue, size large, part # (property) 90418-8104
Bike 1 color yellow, size small, part # (property) 90419-8102
Bike 1 color yellow, size large, part # (property) 90419-8104
Now for the testing...
1.) Initial load: Properties dropdown is now empty -> Correct!
2.) Choose color red but leave size blank -> Properties dropdown shows part # 90418-8004 (aka color red size large) -> OK?
3.) Choose color red, size small -> Properties dropdown shows part 90419-8102 (aka color yellow size small) -> WRONG
4.) Choose color red, size large -> Properties dropdown shows part # 90419-8104 (aka color yellow size large) -> WRONG
5.) Choose color blue, size small -> Properties dropdown shows part # 90419-8102 (aka color yellow size small) -> WRONG
6.) Choose color blue, size large -> Properties dropdown shows part # 90419-8104 (aka color yellow size large) -> WRONG
7.) Choose color yellow, size small -> Properties dropdown shows part # 90418-8104 (aka color yellow size large) -> WRONG
8.) Choose color yellow, size large -> Properties dropdown shows part # 90419-8104 (aka color yellow size large) -> Correct?
9.) Go back to color red, size small -> Properties dropdown shows part 90419-8102 (aka color yellow size small) -> WRONG
It seems to be skipping through the loop? Let me know if you need me to run more scenarios as I have more bikes with more options.
HTH,
-S.
Item: Bike 1
HTH,
-S.
The changes in the aimeos.js file still seems to be not available while the PHP code is now correct in your installation.
superscotty19
Nope,
Here's the code for public_html/typo/typo3conf/ext/aimeos/Resources/Private/Extensions/ai-client-html/client/html/themes/aimeos.js
[code]
} else {
$(".addbasket .btn-action", parent).removeClass("btn-disabled").r$
$(".catalog-detail-additional .subproduct-actual").removeClass("subproduc$
$(".catalog-detail-additional .subproduct-" + prodId).addClass("subproduc$
# Removed as glitch
# $(".catalog-detail-additional .subproduct-actual").removeClass("subproduct-actual");
# $(".catalog-detail-additional .subproduct-" + prodId).addClass("subproduct-actual");
[/code]
... and here's the code for
[code] }
# Removed 20190623
# foreach( $propItems as $propId => $propItem )
foreach( $propItems as $propItem )
# Removed as part of glitch
# $propMap[ $propItem->getType() ][ $propId ] = $propItem;
# $subPropDeps[ $propId ][] = $propItem->getParentId();
$propMap[$propItem->getType()][$propItem->getId()] = $propItem;
$subPropDeps[$propItem->getId()] = $propItem->getParentId();
<?php
# if( $propertyItem->getParentId() != $this->detailProductItem$
# && isset( $subPropDeps[ $propertyItem->getId() ] )
# $classes .= ' subproduct';
# foreach( $subPropDeps[ $propertyItem->getId() ] as $$
# $classes .= ' subproduct-' . $prodid;
if( isset( $subPropDeps[$propertyItem->getId()] ) ) {
$classes .= ' subproduct subproduct-' . $subPropDeps$
[/code]
Plus I've cleared all private data on the browser as well as trying a different browser altogether and clearing opcache on TYPO3.
... but I still get a mess. New example:
Bike2, color teal, size 44cm, has property "MPN" of 90219-6044
Bike2, color teal, size 48cm, has property "MPN" of 90219-6048
Bike2, color teal, size 51cm, has property "MPN" of 90219-6051
Bike2, color teal, size 54cm, has property "MPN" of 90219-6054
Bike2, color teal, size 56cm, has property "MPN" of 90219-6056
Bike2, color black, size 44cm, has property "MPN" of 90219-6144
Bike2, color black, size 48cm, has property "MPN" of 90219-6148
Bike2, color black, size 51cm, has property "MPN" of 90219-6151
Bike2, color black, size 54cm, has property "MPN" of 90219-6154
Bike2, color black, size 56cm, has property "MPN" of 90219-6156
Results:
Initial load, no properties -> Correct
Choose Bike2, color teal, size 51cm -> MPN = 90219-6151 -> WRONG
Choose Bike2, color teal, size 51cm -> MPN = 90219-6144 -> WRONG
Choose Bike2, color black, size 44cm -> MPN = 90219-6156 -> WRONG
Choose Bike2, color black, size 48cm -> MPN = 90219-6156 -> WRONG
Choose Bike2, color black, size 51cm -> MPN = 90219-6156 -> WRONG
Choose Bike2, color black, size 54cm -> MPN = 90219-6156 -> WRONG
Choose Bike2, color black, size 56cm -> MPN = 90219-6156 -> OK but only by luck.
[code]
} else {
# Removed as glitch
[/code]
[code] }
# Removed 20190623
<?php
[/code]
Results:
