Supplier - Item Name - Price on Separate Rows in CatalogList
superscotty19
Re: Supplier - Item Name - Price on Separate Rows in CatalogList
Post by superscotty19 » 17 Jul 2019, 23:07
OK I've implemented your steps but still not seeing the brand. Specifically:
1.) Created brand attributes and assigned them to products
2.) TS->Setup now has:
plugin.tx_aimeos.settings.client.html.catalog.lists.domains {
   0 = media
   1 = price
   2 = text
   3 = attribute
3/4.) Modified products-standard.php ... Full disclosure: In the interest of getting a proof of concept as fast as possible, I modified like this:
  <div class="text-list">
    <h2 itemprop="name"><?= $enc->html( $productItem->getName(), $enc::TRUST ); ?></h2>
         <?php foreach( $productItem->getRefItems( 'text', 'short', 'default' ) as $textItem ) : ?>
                <!-- /* Added by Scott 20190719 to show brand in FE catagloue list */ -->
                <?php if( ( $attrItem = current( $productItem->getRefItems( 'attribute', 'brand', 'default' ) ) ) !== false ) : ?>
                         <?= $enc->html( $attrItem->getName() ) ?>
                <?php endif ?>
                 <div class="text-item" itemprop="description">
                        <?= $enc->html( $textItem->getContent(), $enc::TRUST ); ?><br/>
                 </div>
       <?php endforeach; ?>
   </div>
... but the result is still the same - see attached - just shows media, then description, then price. Need media, then brand, then product/description, then price.
-S.
Screenshot_2019-06-29 Car Racks.png (22.84 KiB) Viewed 5062 times
Post by aimeos » 18 Jul 2019, 17:18
Your code is correct. Can you show how you've assigned the attribute to the product? Is the attribute and type enabled?
superscotty19
Post by superscotty19 » 18 Jul 2019, 21:10
Thanks for the confirmation. Product attribute assignment attached, as well as confirmation the Brand attribute is enabled
-S.
Screenshot_2019-07-18-2 [TYPO3 CMS 8 7 4].png (21.73 KiB) Viewed 5061 times
Screenshot_2019-07-18 [TYPO3 CMS 8 7 4].png (27.5 KiB) Viewed 5061 times
Post by aimeos » 19 Jul 2019, 08:42
Types are case sensitive, so "Brand" and "brand" are different entities.
