Aimeos vs Bagisto and SPA templates
nos3
Re: Aimeos vs Bagisto and SPA templates
Post by nos3 » 19 Sep 2019, 14:50
Seems like you will have the choice between two SPA frontends based on Vue.js next year.
A company from Barcelona build their shops using Aimeos and Vue Storefront and they plan to release their integration code.
vikram
Post by vikram » 17 Aug 2020, 08:14
aimeos wrote: 26 Aug 2019, 09:58 We will create a progressive web application (PWA) which will be easy to adapt and extend in the next few months based on Vue.js and Nuxt.js but that won't help you at the moment. Additionally, we are currently creating a simple to use JS library that hides the tedious details of the JSON REST API. You can find the already existing code here:
https://github.com/aimeos/ai-client-jsonapi
Where can I find more updates on this?
And where can I find this JS library ?
Post by aimeos » 17 Aug 2020, 08:43
We've decided to build a PWA together with other interested parties that isn't specific for Aimeos so it can be used in a greater context. Thus, the project takes longer than expected but will be much better at the end :-)
The simplified jsapi is available here:
https://github.com/aimeos/ai-client-jso ... ster/jsapi
