Aimeons Attributes type
Re: Aimeons Attributes type
Post by aimeos » 25 Apr 2020, 08:05
You can't prevent the JSON API to return them if you use "&include=attribute" in your request but you can filter them out in the client so they are not shown. We will see how we can filter hidden attributes in future versions
traiyani75
Post by traiyani75 » 28 Apr 2020, 09:30
Ok thanks
traiyani75
Post by traiyani75 » 29 Apr 2020, 11:48
hello,
We are good in attributes. Now, I have question related to properties. Can we filter product list using property id?
Post by aimeos » 01 May 2020, 07:35
Yes, but using the product property ID will always return exactly one product:
/jsonapi/product?filter[%3D%3D][product.property.id]=123
https://aimeos.org/docs/Developers/Clie ... the_result
