XML import of product attributes does not work in 19.10.4
Re: XML import of product attributes does not work in 19.10.4
Post by aimeos » 27 Jan 2020, 09:48
You can't copy the files from the master branch as they advanced in the meantime! You should move to a composer based installation to simplify updates.
We've created a TYPO3 pre-release package for you:
https://aimeos.org/fileadmin/download/a ... 5-pre1.zip
cnoelker
Post by cnoelker » 27 Jan 2020, 10:25
Thank you. I checked and the attributes are there, again! :-)
