CSV Import - Products
Re: CSV Import - Products
Post by aimeos » 06 May 2021, 12:05
You have to configure the absolute file system path where your CSV files are stored using "controller/jobs/product/import/csv/location":
- https://aimeos.org/docs/2021.x/cronjobs ... and-format
- https://aimeos.org/docs/2021.x/config/c ... /#location
Post by aimeos » 07 May 2021, 16:53
SinanSakic wrote: 04 May 2021, 09:09 controller.jobs.product.import.csv {
container.type = Directory
location =C:\xampp\htdocs\gourmets\uploads\
Maybe TypoScript is a bit picky here. Can you try:
  location = C:\xampp\htdocs\gourmets\uploads\
Another problem might be that a Windows path may not work.
