Error after Aimeos 19.10 -> 20.4.2 update
bouuman
Re: Error after Aimeos 19.10 -> 20.4.2 update
Post by bouuman » 23 May 2020, 13:09
aimeos wrote: 23 May 2020, 12:58 Can you please check the siteid column in the fe_users table? It should now contain for your records something like "1." if there's a mshop_locale_site.id record with ID 1 or it can be empty string but NOT NULL.
yes this is the problem! thank you!! the new user which i created had a "1." and the other users had a "1"... if i change it to "1.", the user is visible again in the backend.
bouuman wrote: 23 May 2020, 12:46 The theme has been updated and it differs from the 2019.x version, so you have to adapt it if you have already changed it to your own layout.
hmm i used the standard theme from the preconfigured shop, is there a easy way to get it back from the old backup?
Post by aimeos » 24 May 2020, 08:58
bouuman wrote: 23 May 2020, 13:09 yes this is the problem! thank you!! the new user which i created had a "1." and the other users had a "1"... if i change it to "1.", the user is visible again in the backend.
OK, we will improve the migration process to do that automatically in the future.
bouuman wrote: 23 May 2020, 12:46 hmm i used the standard theme from the preconfigured shop, is there a easy way to get it back from the old backup?
Not really as the HTML code also changed a bit. The new theme isn't that far away from the old one, only a bit more slick and clean.
bouuman
Post by bouuman » 24 May 2020, 09:12
Thank you for solving all my problems!
bouuman
Post by bouuman » 29 May 2020, 08:23
Sorry, i have to disturb again... i still have 1 error, when adding items to the basket, can you help me to find out what is this about: (the orders are working, no idea what this error is about):
E Time User Type Action Details Actions
08:17:10 XXXX_XXXXXXXXXX
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: Argument 2 passed to Aimeos\Aimeos\Controller\JsonapiController::getAction() must be of the type string, null given, called in /var/www/vhosts/XXXXX.XXXX.XXXXXXXX.XX/httpdocs/typo3conf/ext/aimeos/Classes/Controller/JsonapiController.php on line 51 | TypeError thrown in file /var/www/vhosts/XXXXX.XXXX.XXXXXXXX.XX/httpdocs/typo3conf/ext/aimeos/Classes/Controller/JsonapiController.php in line 78. Requested URL: https://xxxxxxxxx.xx/jsonapi?ai%%5Breso ... 5D=options
28-05-2020
15:17:00 XXXX_XXXXXXXXXX
14:33:56 [0]
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1518472257: Failed to fetch error page "https://xxxxxxxxx.xx", reason: cURL error 28: Operation timed out after 10000 milliseconds with 0 out of 0 bytes received (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) | RuntimeException thrown in file /var/www/vhosts/XXXXX.XXXX.XXXXXXXX.XX/httpdocs/typo3/sysext/frontend/Classes/Controller/ErrorController.php in line 210. Requested URL: https://xxxxxxxxx.xx/willkommen-bei-bauer-modellbau/
14:17:23 [0]
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1518472257: Failed to fetch error page "https://xxxxxxxxx.xx", reason: Server error: `GET https://xxxxxxxxx.xx` resulted in a `503 Service Unavailable` response: <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>503 Service Unavailable</title> </head><body> <h1 (truncated...) | RuntimeException thrown in file /var/www/vhosts/XXXXX.XXXX.XXXXXXXX.XX/httpdocs/typo3/sysext/frontend/Classes/Controller/ErrorController.php in line 210. Requested URL: https://xxxxxxxxx.xx/robots.txt
14:17:06 [0]
14:15:00 [0]
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1518472257: Failed to fetch error page "https://xxxxxxxxx.xx", reason: cURL error 28: Resolving timed out after 10287 milliseconds (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) | RuntimeException thrown in file /var/www/vhosts/XXXXX.XXXX.XXXXXXXX.XX/httpdocs/typo3/sysext/frontend/Classes/Controller/ErrorController.php in line 210. Requested URL: https://xxxxxxxxx.xx/xxxx-shop/xyzkateg ... nter%%5D=2
14:09:36 [0]
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1518472257: Failed to fetch error page "https://xxxxxxxxx.xx", reason: Server error: `GET https://xxxxxxxxx.xx` resulted in a `504 Gateway Time-out` response: <html> <head><title>504 Gateway Time-out</title></head> <body> <center><h1>504 Gateway Time-out</h1></center> <hr><c (truncated...) | RuntimeException thrown in file /var/www/vhosts/XXXXX.XXXX.XXXXXXXX.XX/httpdocs/typo3/sysext/frontend/Classes/Controller/ErrorController.php in line 210. Requested URL: https://xxxxxxxxx.xx/xxxx-shop/xyzkateg ... 75d54638da
14:05:43 [0]
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1518472257: Failed to fetch error page "https://xxxxxxxxx.xx", reason: cURL error 28: SSL connection timeout (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) | RuntimeException thrown in file /var/www/vhosts/XXXXX.XXXX.XXXXXXXX.XX/httpdocs/typo3/sysext/frontend/Classes/Controller/ErrorController.php in line 210. Requested URL: https://xxxxxxxxx.xx/kontaktformular/
14:03:01 [0]
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1518472257: Failed to fetch error page "https://xxxxxxxxx.xx", reason: cURL error 28: Operation timed out after 10000 milliseconds with 0 out of 0 bytes received (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) | RuntimeException thrown in file /var/www/vhosts/XXXXX.XXXX.XXXXXXXX.XX/httpdocs/typo3/sysext/frontend/Classes/Controller/ErrorController.php in line 210. Requested URL: https://xxxxxxxxx.xx/robots.txt
13:19:51 [0]
LIVE ERROR Error handler Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1518472257: Failed to fetch error page "https://xxxxxxxxx.xx", reason: Server error: `GET https://xxxxxxxxx.xx` resulted in a `503 Service Unavailable` response: <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>503 Service Unavailable</title> </head><body> <h1 (truncated...) | RuntimeException thrown in file /var/www/vhosts/XXXXX.XXXX.XXXXXXXX.XX/httpdocs/typo3/sysext/frontend/Classes/Controller/ErrorController.php in line 210. Requested URL: https://xxxxxxxxx.xx/xxxx/xyzkategorie1 ... 87fff76b11
Post by aimeos » 29 May 2020, 08:35
bouuman
Post by bouuman » 29 May 2020, 12:43
aimeos wrote: 29 May 2020, 08:35 Please use this pre-release: https://aimeos.org/fileadmin/download/a ... 3-pre4.zip
ok looks good so far thank you!
bouuman
Post by bouuman » 31 May 2020, 08:56
suddenly, when i click my "Categorys" menu, nothing happens, they dont pupup..
Thats strange, because i did no changes on that, maybe some kind of cache was emptyed now.
and my picture previews are gone from the main page
(still can click a article and add it to cart and access the cart, the picture of the article is only shown if i click on the article) ...but the menu is dead and the picture previews also on the main page.)
I would appreciate it if you could help me on that because im not sure after which update it happened and i cant roll back the data because some new orders was placed.
this is in the typo3conf var log:
Sun, 31 May 2020 09:33:20 +0000 [WARNING] request="f37b547a62573" component="TYPO3.CMS.Frontend.Configuration.TypoScript.ConditionMatching.ConditionMatcher": Expression could not be parsed, fallback kicks in. It looks like an old condition with only one equal sign. - {"expression":"globalVar = TSFE:type=191351524"}
Sun, 31 May 2020 09:33:20 +0000 [WARNING] request="f37b547a62573" component="TYPO3.CMS.Frontend.Configuration.TypoScript.ConditionMatching.ConditionMatcher": Expression could not be parsed, fallback kicks in. It looks like an old condition with only one equal sign. - {"expression":"globalVar = TSFE:type=191351525"}
Sun, 31 May 2020 09:33:24 +0000 [WARNING] request="4ad7ad47d997a" component="TYPO3.CMS.Frontend.Configuration.TypoScript.ConditionMatching.ConditionMatcher": Expression could not be parsed, fallback kicks in. It looks like an old condition with only one equal sign. - {"expression":"globalVar = TSFE:type=191351524"}
Sun, 31 May 2020 09:33:24 +0000 [WARNING] request="4ad7ad47d997a" component="TYPO3.CMS.Frontend.Configuration.TypoScript.ConditionMatching.ConditionMatcher": Expression could not be parsed, fallback kicks in. It looks like an old condition with only one equal sign. - {"expression":"globalVar = TSFE:type=191351525"}
Post by aimeos » 02 Jun 2020, 12:29
Don't know why your category images should be gone. If the categories doesn't open, please check if there's JS error in the browser console or there's a margin from a TYPO3 content element (those with Frame: Default) which is overlapping the category link.
bouuman
Post by bouuman » 02 Jun 2020, 13:36
aimeos wrote: 02 Jun 2020, 12:29 Don't know why your category images should be gone. If the categories doesn't open, please check if there's JS error in the browser console or there's a margin from a TYPO3 content element (those with Frame: Default) which is overlapping the category link.
yes i see this errors:
Post by aimeos » 02 Jun 2020, 14:53
jQuery is missing, you haven't included it in your pages.
