Favorite list
traiyani75
Re: Favorite list
Post by traiyani75 » 13 Jul 2020, 15:06
Very well. Please update me pls whenever its done
Re: Favorite list
Post by aimeos » 11 Aug 2020, 18:02
How to manage favorite and watched products (as well as other relations) is now documented here:
https://github.com/aimeos/aimeos-docs/b ... lations.md
The generated docs from that source will look nicer but in the meantime this should help to get it implemented.
traiyani75
Re: Favorite list
Post by traiyani75 » 18 Aug 2020, 05:16
Thank you, I checked it.
For my case, when we call customer end points, we are not getting link for relationships. It is returning following links only
"links": {
"self": "http://ebdaa-ecommerce-beta.mzadqatar.c ... mer?id=323",
"customer/address": {
"href": "http://ebdaa-ecommerce-beta.mzadqatar.c ... ed=address",
"allow": [
"GET",
"POST"
And when I tried to call API to add relationships for favorite product like this
API : http://ebdaa-ecommerce-beta.mzadqatar.c ... ationships
request : {"data": [{ "attributes": { "customer.lists.domain": "product", "customer.lists.type": "favorite", "customer.lists.refid": "9", "customer.lists.datestart": null, "customer.lists.dateend": null, "customer.lists.config": {}, "customer.lists.position": 0, "customer.lists.status": 1 } }]}
It is added relation with customer, which I can see when I call get request on relationships api: below one
http://ebdaa-ecommerce-beta.mzadqatar.c ... de=product
So, Only issue is that relationships link is not coming into customer endpoint.
Questions
How do I add extra information of product along with product id?
Also Will these relationships support localization?
traiyani75
Re: Favorite list
Post by traiyani75 » 25 Aug 2020, 08:36
Hello guys, Do we have any update?
Re: Favorite list
Post by aimeos » 25 Aug 2020, 09:17
traiyani75 wrote: 18 Aug 2020, 05:16 So, Only issue is that relationships link is not coming into customer endpoint.
This is only available in dev-master and and the latest 2020.07.x-dev branch yet.
traiyani75 wrote: 18 Aug 2020, 05:16 How do I add extra information of product along with product id?
You can add arbitrary information in the "customer.lists.config" object.
traiyani75 wrote: 18 Aug 2020, 05:16 Also Will these relationships support localization?
The relationships itself doesn't contain any localized information and you should not write any localized strings into the config field. You can add key/value pairs to the config and translate the keys and values in the frontend or you store the localized strings and product texts.
