Questions by URL and breadcrumbs
Re: Questions by URL and breadcrumbs
Post by aimeos » 06 Dec 2020, 17:48
These lines are responsible for adding the parameters to the session so the breadcrumb shows up in the detail view:
https://github.com/aimeos/ai-client-htm ... #L417-L428
If you reset the session value here, the breadcrumb should be correctly:
https://github.com/aimeos/ai-client-htm ... d.php#L350
Can you check this and if it works create a pull request on Github with the fix afterwards?
Dinver
Post by Dinver » 07 Dec 2020, 07:59
aimeos wrote: 06 Dec 2020, 17:48 These lines are responsible for adding the parameters to the session so the breadcrumb shows up in the detail view:
Thanks helped! :)
