How to test the extension classes ?
dheeraj
Re: How to test the extension classes ?
Post by dheeraj » 12 Jun 2021, 10:03
Hello.
I am getting an error while executing some test cases in which TestHelper class is used.
This error comes with aimeos extensions too.
PHP Warning:  Uncaught require_once(Bootstrap.php): failed to open stream: No such file or directory
The error is occurring due to the statement require_once('Bootstrap.php') in the TestHelper class in the extension but
this Bootstrap.php is only present in the aimeos-core package and not in any of the extensions (custom + ai-*).
As a reminder, i am testing extensions directly in the project instead of copying extensions to a cloned aimeos-core repo.
The test command that i am executing is below :-
vendor/bin/phpunit --bootstrap=vendor/autoload.php -c ext/ext-custom/lib/custom/tests/phpunit.xml
Post by aimeos » 16 Jun 2021, 08:51
That's strange because composer (used by including vendor/autoload.php) should know the \Aimeos\Bootstrap class located in vendor/aimeos/aimeos-core/
