issues in Implementing Delivery Provider
khizar
Re: issues in Implementing Delivery Provider
Post by khizar » 08 Apr 2021, 05:04
Hey guys waiting for reply
khizar
Post by khizar » 08 Apr 2021, 09:17
hey guys please have a look at this problem
Post by aimeos » 09 Apr 2021, 07:08
khizar wrote: 07 Apr 2021, 11:39
        if($t->data[0]->success){
        // here is the code for saving attributes
            $status = \Aimeos\MShop\Order\Item\Base::STAT_PROGRESS;
            $order->setDeliveryStatus( $status );
            // $this->saveOrder( $order );
            $attributes = ['reference_number' => $t->data[0]->reference_number];
            $serviceType = \Aimeos\MShop\Order\Item\Base\Service\Base::TYPE_DELIVERY;
            $orderServiceItem = $order->getService( $serviceType );
            $this->setAttributes( $orderServiceItem, $attributes, 'myprovider' );
            $this->saveOrderBase( $basket );
        return $order;
Your code looks correct.
khizar wrote: 07 Apr 2021, 11:39 Now if above code is right can you please tell me how can i access that reference no in orders list
	<?php foreach( $this->get( 'items', [] ) as $id => $item ) : ?>
	<?php endforeach; ?>
please note that the above foreach loop is from the orders list and it contains code but for the sake of simplicity i picked up only start and end of the loop can you please tell me here how can i access that reference number
In the order list view it's more difficult because the order details are not loaded there:
https://github.com/aimeos/ai-client-htm ... d.php#L218
You would have to overwrite that method with your own version in your own extension and use:
$view->listsOrderItems = $cntl->uses( ['order/base', 'order/base/service'] )->sort( '-order.id' )->search();
Then, you can get the reference in the loop using:
if( $service = current( $item->getBaseItem()->getService( 'delivery' ) ) ) {
	$ref = $service->getAttribute( 'reference_number', 'myprovider' );
https://github.com/aimeos/aimeos-core/b ... e.php#L151
Note: We answer questions in the forum in our spare time.
If you need immediate response, please ask the Aimeos company for paid support:
https://aimeos.com/support
khizar
Post by khizar » 09 Apr 2021, 07:18
aimeos wrote: 09 Apr 2021, 07:08
        return $order;
I have completed my task .I want to you to have a look at my code and guide me is it correct or not so that i can move on to next task .i am getting my desired result but not sure my approach is right or not so please guide me.i am posting my code below
<?php
namespace Aimeos\MShop\Service\Provider\Delivery;
use Illuminate\Support\Facades\DB;
use Illuminate\Support\Facades\Http;
use Illuminate\Support\Facades\Log;
class Myprovider
extends \Aimeos\MShop\Service\Provider\Delivery\Base
implements \Aimeos\MShop\Service\Provider\Delivery\Iface
     * Sends the order details to the ERP system for further processing.
     * @param \Aimeos\MShop\Order\Item\Iface $order Order invoice object to process
    public function process(\Aimeos\MShop\Order\Item\Iface $order): \Aimeos\MShop\Order\Item\Iface
        $parts = \Aimeos\MShop\Order\Item\Base\Base::PARTS_ALL;
        $basket = $this->getOrderBase($order->getBaseId(), $parts);
	$data = []; // note that it contains data but i have skipped that part
        $apiurl = 'http://demodashboardapi.shipsy.in/api/customer/integration/consignment/softdata';
        $response =  Http::withHeaders([
            "api-key" => "XXXXXXXXXXXXXX",
            "Content-Type" => "application/json"
        ])->post($apiurl,$data);
        $t = json_decode($response);
            info('entered into success method');
            $attributes = ['reference_number' => $t->data[0]->reference_number,'message'=>''];
            $orderServiceItem = $basket->getService( $serviceType );
            if(($serviceItem = reset($orderServiceItem)) !== false){
                $this->setAttributes( $serviceItem, $attributes, 'myprovider' );
        }else{
            $attributes = ['reference_number' => '', 'message' => $t->data[0]->message];
        return $order;
Now in my list orders i picked up service attribute by using
<?php
$baseItems = $this->get( 'baseItems', [] );
                $baseItem = ( isset( $baseItems[$item->getBaseId()] ) ? $baseItems[$item->getBaseId()] : null );
					$reference_no = '';
					$message  = '';
					$orderServiceItem = $baseItem->getService( $serviceType );
						$reference_no = $serviceItem->getAttribute( 'reference_number', 'myprovider' );
						// $attrItem = $serviceItem->getAttributeItem( 'reference_number', 'myprovider' );
						$message = $serviceItem->getAttribute( 'message', 'myprovider' );
			endforeach:
That code is working perfectly but i want you to have a look if it need any modification .please guide me
Post by aimeos » 11 Apr 2021, 12:01
In principle, it should be correct.
