mysql optimization/clarification
MikaelNazarenko
Expert
Re: mysql optimization/clarification
Post by MikaelNazarenko » 15 May 2021, 18:23
I have done a quick test.
In blade view I added this code:
for($i = 0; $i < 10; $i++) {
    aitrans('April');
And modified a bit /vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Base/Locale.php:
	public function get( \Aimeos\MShop\Context\Item\Iface $context ) : \Aimeos\MShop\Locale\Item\Iface
		if( $this->locale === null )
			$site = Request::input( 'site', 'default' );
			$lang = Request::input( 'locale', app()->getLocale() );
			$currency = Request::input( 'currency', '' );
			if( Route::current() )
				$site = Request::route( 'site', $site );
				$lang = Request::route( 'locale', $lang );
				$currency = Request::route( 'currency', $currency );
			$localeManager = \Aimeos\MShop::create( $context, 'locale' );
			$disableSites = $this->config->get( 'shop.disableSites', true );
			$this->locale = $localeManager->bootstrap( $site, $lang, $currency, $disableSites );
                        dump(spl_object_id($this));
		return $this->locale;
The output is:
382
742
836
879
922
965
1008
1051
1094
1137
1180
Means the Aimeos\Shop\Base\Locale is always different object.. This is why $this->locale === null is always true .. (
Do you have ideas ?
Post by aimeos » 16 May 2021, 07:17
It seems like the singleton method isn't only executed once but each time a context is requested:
https://github.com/aimeos/aimeos-larave ... hp#L84-L86
MikaelNazarenko
Expert
Post by MikaelNazarenko » 16 May 2021, 10:14
Hi )
for($i = 0; $i < 100; $i++) {
    /** @var \Aimeos\Shop\Base\Context $context */
    $context = app( '\Aimeos\Shop\Base\Context' );
    $context->get();
The above code makes the error. It get extra connection for each call.
I checked like you suggested if I understand you right like this:
$this->app->singleton( 'aimeos.locale', function( $app ) {
            dump(234);
            return new \Aimeos\Shop\Base\Locale( $app['config'] );
$this->app->singleton( 'aimeos.context', function( $app ) {
            dump(234);
            return new \Aimeos\Shop\Base\Context( $app['session.store'], $app['aimeos.config'], $app['aimeos.locale'],
                   $app['aimeos.i18n'] );
And it printed only once. So I think it is called only once.
Again in /vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Base/Locale.php:
it printed as much as I called $context->get(); in loop. And id is different, so it is always different object.. (
Could not you try to reproduce it please ?
MikaelNazarenko
Expert
Post by MikaelNazarenko » 16 May 2021, 10:49
But I think the biggest problem even with project with oldest aimeos project...
I just recorded general mysql log for one request in BE dashboard. Of course I have cleared log before and just one time opened dashboard in browser.. A lot of queries and connections ( 150 connections just to visit BE dashboard..
All custom code I have removed before test..
max_user_connections = 40, user connections error was not appeared.. but lot connections and queries, I think so.. Where is a problem ? And also I noticed a lot ajax request you can see on screenshot.
here is full mysql general log https://temp.pm/?jX5Ah9dbYdYNa3pibWoQD7 ... lu0tjOwT-N
Is it really aimeos is so expensive for mysql ? I would be really pity about that :( Or what might be wrong ?
components versions are:
aimeos/ai-admin-jqadm                 2019.10.6  Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm               2019.10.2  Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html                 2019.10.10 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi              2019.10.2  Aimeos JSON API extension
aimeos/ai-controller-frontend         2019.10.3  Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs             2019.10.4  Aimeos ai-controller-jobs extension
aimeos/ai-gettext                     2019.10.1  Aimeos Gettext extension
aimeos/ai-laravel                     2019.10.2  Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-payments                    2019.10.1  Payment extension for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer                 2019.10.1  SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core                    2019.10.7  Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel                 2019.10.1  Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
I hope very much we can figure it out. Thank you !
Screenshot from 2021-05-16 13-39-52.png (229.84 KiB) Viewed 14089 times
Post by aimeos » 16 May 2021, 12:03
Why is the Locale object always different if these singletons are only called once?
            dump(234);
            dump(234);
The Locale object injected into the context is stored once and used several times:
- https://github.com/aimeos/aimeos-larave ... xt.php#L63
- https://github.com/aimeos/aimeos-larave ... t.php#L102
MikaelNazarenko
Expert
Post by MikaelNazarenko » 16 May 2021, 17:27
Honestly I don't know, but I tried the below code in blade view and in search() method of dashboard Standard:
dump(spl_object_id(app( '\Aimeos\Shop\Base\Context' )->get()));
The output is:
1370
1411
1427
spl_object_id is different. Does it mean the objects are different right ? I think it must be the same object.. Why it happens I don't know really, I thought we could find out it together faster.. Is not it the same behavior on your side ?
Here is also different ids:
/** @var \Aimeos\Shop\Base\Context $c */
$c = app( '\Aimeos\Shop\Base\Context' );
$a = app( '\Aimeos\Shop\Base\Context' );
dump(spl_object_id($a));
dd(spl_object_id($c));
MikaelNazarenko
Expert
Post by MikaelNazarenko » 17 May 2021, 08:08
Should this call always return the same object app( '\Aimeos\Shop\Base\Context' ) ?
MikaelNazarenko
Expert
Post by MikaelNazarenko » 18 May 2021, 10:35
aitrans() function consists app( '\Aimeos\Shop\Base\Context' )
this call app( '\Aimeos\Shop\Base\Context' ) - seems doesn't trigger singleton and as result it returns always new object, and therefor context inside itself performs extra mysql queries..
But if I use it so: app( 'aimeos.context' ) - then the same object is always returned.
Am I wrong ? What will you say ?
Post by aimeos » 23 May 2021, 07:43
MikaelNazarenko wrote: 18 May 2021, 10:35 aitrans() function consists app( '\Aimeos\Shop\Base\Context' )
Thanks for tracking this down. It's now changed to "aimeos.context" and available in dev-master, 2021.04.x-dev, 2020.10.x-dev and 2019.10.x-dev
MikaelNazarenko
Expert
Post by MikaelNazarenko » 24 May 2021, 06:27
No problem, I am glad to cooperate!
these are my packages versions:
aimeos/ai-admin-jqadm                     2021.04.6 Aimeos Vue.js+Bootstrap admin interface
aimeos/ai-admin-jsonadm                   2021.04.1 Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html                     2021.04.7 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi                  2021.04.1 Aimeos JSON API extension
aimeos/ai-cms-grapesjs                    2021.04.2 Aimeos GrapesJS CMS extension
aimeos/ai-controller-frontend             2021.04.1 Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs                 2021.04.3 Aimeos ai-controller-jobs extension
aimeos/ai-gettext                         2021.04.1 Aimeos Gettext extension
aimeos/ai-laravel                         2021.04.3 Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer                     2021.04.1 SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core                        2021.04.3 Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel                     2021.04.2 Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
Please, give me a tip, how do I grab the updates for 2021.04.2 but I want to leave 2021.04.2 and do not get it updated to higher ?
Thanks a lot !
