Extern Userdatabase
Re: Extern Userdatabase
Post by aimeos » 12 Jan 2022, 08:39
You need to execute the Aimeos update script to add the necessary columns after you've added the "db-customer" resource configuration.
Shopmister
Post by Shopmister » 13 Jan 2022, 06:26
I see. Now its showing the users in the aimeos Customer Module :).
Buzt next problem is. Its not possible to login with that users about the typo3 Login CE at aimeos Installation. Same about checkout. That tells me that it need more to do, because Aimeos dont know in FE too that are an User logged in.
What i have to do next that i can login at aimeos instalaltion in FE too?
Post by aimeos » 14 Jan 2022, 09:39
Did you configure the PID of the "Users" sysfolder like written before:
https://aimeos.org/docs/2021.x/config/m ... id-default
Shopmister
Post by Shopmister » 14 Jan 2022, 13:53
For sure. But in general i dont have an idea how aimeos could get the data, if the user in the current installation not logged in. And if the user logged in in the extern installation aimeos become user dta from, i have no idea how that with the cookies for login works.
Post by aimeos » 17 Jan 2022, 08:23
You can use the fe_users table from an extern database but not from a foreign TYPO3 installation. The TYPO3 installation must be the same because TYPO3 must know its fe_user records to manage login state.
