Login Username and Emailadresse
Re: Login Username and Emailadresse
Post by aimeos » 24 Nov 2021, 16:51
For a single site installation, there are no consequences besides the records can't be managed in the Aimeos customer panel.
Shopmister
Post by Shopmister » 24 Nov 2021, 18:23
Thankls for answer. But sorry, i dont understand. wich records cant be managed. i can change the language, the adresses, the etc. or what you mean cant be managed?
Post by aimeos » 25 Nov 2021, 13:59
You can't change customer data (or only as super user).
Shopmister
Post by Shopmister » 25 Nov 2021, 14:21
Sorry, my fail i changed the answer in topic but wasnt logged in and it didnt works. ^^.
I can change only the drag and drops and not adress etc, yea :).
What i wanted to ask, if i can change i f need in database the site id field the empty, to "1." . atm is 1. in that field if the register about checkout :)
The only field that arent so like i need(but its not very importand) is that:
It is possible to set the billing country in backend modul germany as standard, thats solute the miniproblem that in backend the billing adress "afghanistan"? per typoscript maybe?
Post by aimeos » 26 Nov 2021, 12:43
Shopmister wrote: 25 Nov 2021, 14:21 The only field that arent so like i need(but its not very importand) is that:
Please create a new topic for that
