How can i create text page teamplate (like About Us)
yeh
Re: How can i create text page teamplate (like About Us)
Post by yeh » 03 Aug 2022, 09:42
My src/views/catalog/detail.blade.php from package aimeos-laravel is:
@extends('moderation-theme::base')
@section('aimeos_header')
    <?= $aiheader['locale/select'] ?? '' ?>
    <?= $aiheader['basket/mini'] ?? '' ?>
    <?= $aiheader['catalog/tree'] ?? '' ?>
    <?= $aiheader['catalog/search'] ?? '' ?>
    <?= $aiheader['catalog/stage'] ?? '' ?>
    <?= $aiheader['catalog/detail'] ?? '' ?>
    <?= $aiheader['catalog/session'] ?? '' ?>
@stop
@section('aimeos_head_basket')
    <?= $aibody['basket/mini'] ?? '' ?>
@stop
@section('aimeos_head_nav')
    <?= $aibody['catalog/tree'] ?? '' ?>
@stop
@section('aimeos_head_locale')
    <?= $aibody['locale/select'] ?? '' ?>
@stop
@section('aimeos_head_search')
    <?= $aibody['catalog/search'] ?? '' ?>
@stop
@section('aimeos_stage')
    <?= $aibody['catalog/stage'] ?? '' ?>
@stop
@section('aimeos_body')
    <?= $aibody['catalog/detail'] ?? '' ?>
@stop
@section('aimeos_aside')
    <?= $aibody['catalog/session'] ?? '' ?>
@stop
santfather
Post by santfather » 03 Aug 2022, 09:51
doesn't work at all or only on a web server?
we had a problem that everything worked locally, but when transferring to the aws server, it was not displayed
yeh
Post by yeh » 03 Aug 2022, 09:58
It doesn't work anywhere unfortunately.
santfather
Post by santfather » 03 Aug 2022, 10:01
try adding to PageController.php(aimeos-laravel\src\Aimeos\Shop\Controller\PageController.php) this line
"foreach( app( 'config' )->get( 'shop.page.cms', ['cms/page', 'catalog/tree', 'catalog/search'] ) as $name )"
yeh
Post by yeh » 03 Aug 2022, 10:10
Thanks, but even after this change, the menu still does not show.
santfather
Post by santfather » 03 Aug 2022, 10:14
last. check pls \aimeos-laravel\src\views\page\index.blade.php @section('aimeos_nav')
<?= $aibody['catalog/tree'] ?? '' ?> it must be there
and of course, clear the entire cache wherever possible :)
yeh
Post by yeh » 03 Aug 2022, 10:24
Yes, that is already in there and all caches etc have been cleared but still no menu :(
santfather
Post by santfather » 03 Aug 2022, 10:29
src/Aimeos/Shop/Controller/PageController.php
src/views/page/index.blade.php
our problem was solved by editing these two files.
I have answered everything I knew on this issue
yeh
Post by yeh » 03 Aug 2022, 10:37
It seems my files already have these changes but the menu is still absent. Thanks for providing your help though.
Maybe Aimeos can help further.
Post by aimeos » 03 Aug 2022, 12:24
First of all: Don't change any files in the vendor directory! Never!
You won't be able to update your installation any more to get bugfixes and security fixes.
If you are working with different themes, make sure you have adapted the templates of your custom theme(s).
@yep: Make sure that your "pages" section in the ./config/shop.php file contains this to display the categories in the CMS pages: https://github.com/aimeos/aimeos/blob/m ... op.php#L61
