Delivery Pickup Date and Time
Re: Delivery Pickup Date and Time
Post by aimeos » 02 Dec 2022, 07:36
The keys before the dots should be named like the lower case decorator name so it's clear they belong together. "deliverydatetime" is good if your decorator is named "Deliverydatetime". The name of the keys after the dot only depends on what your decorator expects.
peter69
Post by peter69 » 02 Dec 2022, 14:07
Thank you very much for your reply,
Where I have doubts, is in the frontend part. How should I name or what values should I set the inputs so that they are saved correctly?
For example, is it correct if I set it as follows:
<div id="time-slots">
		<input
                    type="text"
                    class="config-key form-control hidden"
                    tabindex="1"
                    name="item[config][key][]"
                    autocomplete="off"
                    value="deliverydatetime.slots"
                <input
                    type="text"
                    v-model="timeslots"
                    name="item[config][val][]"
                    class="config-value config-type config-type-map hidden"
</div>
Regards,
Post by aimeos » 04 Dec 2022, 10:26
Yes, this may work if the value is a multi-dimensional data field.
