Image Format WebP
Moritz
Re: Image Format WebP
Post by Moritz » 23 Jan 2023, 07:43
It happens with imagemagick and graphicmagick.
PHP 8.2.24
Typo3 v12.4.23 LTS
Aimeos web shop 24.10.2
Moritz
Post by Moritz » 23 Jan 2023, 07:56
The image processing test case "jpg to webp" in Typo3 are working.
PHP 8.2.24
Typo3 v12.4.23 LTS
Moritz
Post by Moritz » 20 Mar 2023, 08:18
Do you found a solution for that?
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 20 Mar 2023, 08:30
No. The best way to solve this is if you can tell us where the problem in the resize() method of the Imagick and/or Standard media class is.
SoundOfSilence
Post by SoundOfSilence » 05 Apr 2023, 16:28
Hi guys,
I was wondering, is there a way to add these settings via Typoscript? In the Constants.ts for example?
Post by aimeos » 11 Apr 2023, 08:13
Typoscript is bound to pages and is a bad idea for settings that should be also available in scheduler tasks or the backend.
