Mobilpay for Typo3
Bollerx
Re: Mobilpay for Typo3
Post by Bollerx » 18 Jan 2016, 14:56
I found a documentation, where you can find answers on how it's work, you can check it for details too.
The problem is that i can't upload here because it doesn't allow me pdf file extensions for the attachment.
Bollerx
Post by Bollerx » 19 Jan 2016, 07:35
i send it to you an e-mail here to aimeos user with the link to the documentation. In case you didn't received it i post it here:
sent by email...
Post by aimeos » 19 Jan 2016, 13:16
OK, if the payment details are collected on the gateway side, then your only configuration options for the Omnipay provider should be:
- omnipay.type = MobilPay
- omnipay.testmode = 1
- merchantId = ...
- publicKey = /path/to/...
If it works correct, you should get at least to the MobilPay gateway where you can enter the payment data.
Bollerx
Post by Bollerx » 19 Jan 2016, 13:59
I configured but i have the same error. Any ideas?
Post by aimeos » 19 Jan 2016, 14:20
Bollerx wrote:I configured but i have the same error. Any ideas?
The MobilPay driver expects a non-standard value for the order ID. It used "orderId" instead of "transactionId":
https://github.com/BusinessMastery/omni ... t.php#L226
Maybe you can create a PR the author is willing to merge.
The parameter "details" is also something that is non-standard and will make problems because we don't know what it is and Aimeos won't hand it over.
