Bulk photo import and automatic product creation
Re: Bulk photo import and automatic product creation
The text type is not correct for example. You have a working example file here:
https://aimeos.org/docs/latest/cronjobs ... est-import
I tried uploading a working example (I deleted the mapping.), and in the admin, only one of the three products shows up.
Yet, the log displays that two out of three were imported..
2024-05-02 21:09:03 import/csv/product 6 58132be6f0c404c629d48dd85d1ed352 Finished product import from "product/default"
2024-05-02 21:09:03 import/csv/product 6 58132be6f0c404c629d48dd85d1ed352 Finished product import from "product/default/products-import-example.csv" (2/3)
5920 select job_csv_test job csv test selection
What is wrong with currencyid?
Please, hlep. ^^
shop.php:
import.csv:
Admin log:
I've installed a completely new Aimeos, without a single modification.
What am I missing? Could it possibly be any simpler? ^^
Plus: How should I write the path to an image that is located in ./public/media/00001.jpg?
For an infinite quantity, should I enter the symbol ∞?
Please, hlep. ^^
shop.php:
'controller' => [
'frontend' => [
'catalog' => [
'levels-always' => 7 // number of category levels for mega menu
'jobs' => [
'product' => [
'import' => [
'csv' => [
'location' => 'product',
'skip-lines' => 1,
'mapping' => [
'item' => [
0 => 'product.code',
1 => 'product.label',
2 => 'product.type',
3 => 'product.status',
'media' => [
4 => 'media.url',
'price' => [
5 => 'price.currencyid',
6 => 'price.quantity',
7 => 'price.value',
8 => 'price.taxrate',
'catalog' => [
9 => 'catalog.code',
10 => 'catalog.lists.type',
product.code,product.label,product.type,product.status,media.url,price.currencyid,price.quantity,price.value,price.taxrate,catalog.code,catalog.lists.type
00001,00001,default,1,https://aimeos.org/media/default/product_01_A-big.webp,EUR,1,50,0,bob,default
Unable to import product with code "00001": Invalid ISO currency code
Seems to be OK and we can see no error in your mapping or your file. EUR as currency is also activated by default after a standard installation.ondrei wrote: 03 May 2024, 04:04 What is wrong with currencyid?Code: Select all
Put the files in ./public/aimeos/files/ and use "files/00001.jpg" as image path in your CSV file. But keep in mind that these files are public and everyone can download them if they know the path.ondrei wrote: 03 May 2024, 04:04 Plus: How should I write the path to an image that is located in ./public/media/00001.jpg?
No, leave it empty.
