Search Filter
Re: Search Filter
Post by aimeos » 15 May 2016, 08:57
We've tested with your example but we get the expected result. That means, the problem is something different.
Maybe "Kabel" is treated as a stop word because it's part of almost every result. Can you try with "Erdung" again and tell us if that works better?
