Basket locale() error after upgrade to 2024.10
Re: Basket locale() error after upgrade to 2024.10
Unfortunately this did not resolve the error, the message remains unchanged:aimeos wrote: 03 Dec 2024, 09:19 Can you try this change: https://github.com/aimeos/aimeos-core/c ... a62e13e3fa
Maybe it's already enough.
Typed property Aimeos\MShop\Price\Item\Standard::$precision must not be accessed before initialization
in packages / <my extension> / src / MShop / Price / Item / Standard.php : 166
Are there any other options or is it really only possible to delete the old shopping baskets as described by jafo66?
jafo66 wrote: 03 Dec 2024, 17:49 Not the best answer, but I had to clear out all the old baskets, then everything started working properly again.
If you find out what must be changed in the price item, we are happy to merge the required change into the next release.
