woocommerce migration not working for nested categories
whYME
Re: woocommerce migration not working for nested categories
Post by whYME » 06 Dec 2024, 15:39
ah, ok, I had it the other way around
'resource' => [
    'db-woocommerce' => [
    'db' => [
Although I would think I should get a SQL error for trying to update a non-existent table?
Post by aimeos » 06 Dec 2024, 15:43
whYME wrote: 06 Dec 2024, 15:39 Although I would think I should get a SQL error for trying to update a non-existent table?
Yes, you should! Does it work if you reorder the resource definitions?
