[SOLVED] How to start index of importing items? (Elasticsearch)
Re: How to start index of importing items? (Elasticsearch)
Post by aimeos » 21 Feb 2025, 12:55
Everything seems to be correct on your side. Can you please run "composer up" and try again? Just want to be sure that the latest aimeos-core page relaeased today (2024.10.13) doesn't already fix the problem.
ЕвгенияСемихова(ИПСемиховаЕ.А.)
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 21 Feb 2025, 13:20
I have write command:
php cpmposer up
at console:
1) After this I send 4 clear command (like at instruction: https://aimeos.org/docs/latest/laravel/setup/#process ):
php ./artisan aimeos:setup
php ./artisan route:clear
php ./artisan view:clear
php ./artisan aimeos:clear
2) delete all items at admin side. Loading csv file, start to inport command and then:
nothing, only in admin side, not at front :(
UPD: send command for index #5 (from 1 to 4 is old ideal item from default store):
          "index.siteid" : [
            "1."
          "index.attributeid" : [ ],
          "index.supplierid" : [ ],
          "index.supplierloc" : [ ],
          "index.catalogid" : [ ],
          "index.price:value(RUB)" : 50.0,
          "index.text:url(en)" : "transistor-1",
          "index.text:name(en)" : "Transistor 1",
          "index.text:content(en)" : [
            "TMP0000001",
            "Transistor 1"
          "index.text:url(ru)" : "transistor-1",
          "index.text:name(ru)" : "Transistor 1",
          "index.text:content(ru)" : [
            "TMP0000001",
            "Transistor 1"
          "index.text:url(zh)" : "transistor-1",
          "index.text:name(zh)" : "Transistor 1",
          "index.text:content(zh)" : [
            "TMP0000001",
            "Transistor 1"
          "index.text:url()" : "transistor-1",
          "index.text:name()" : "Transistor 1",
          "index.text:content()" : [
            "short test",
            "Описание находится в очереди на редактирование",
            "Transistor 1"
and again, if open and save item card from admin side - then:
          "index.siteid" : [
            "1."
          "index.catalog" : [
              "position" : 0,
              "listtype" : "default",
              "id" : "15"
            "15"
            "TMP0000001",
            "Электронные компоненты",
            "Transistor 1"
Debian 12, PHP 8.3, Server 1 = Aimeos 2024.10.13, Server 2 = ES 8.17.1
life is full of many new and interesting things
Post by aimeos » 24 Feb 2025, 11:12
Thanks to your help, we've found the problem. The CSV importer wasn't adding the categories as required and we've fixed that now. Can you please update to aimeos/ai-controller-jobs:2024.10.x and check if it works for you too?
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 24 Feb 2025, 12:51
I just copy two catalogs from your github (ai-controller-jobs) to my server ("src/Controller" and "tests"), right?
After copy I've clear cach and import csv file - dear, it works!!!
Thanks for your help! We will go to the next level!
Post by aimeos » 24 Feb 2025, 12:54
Always use composer and run "composer req aimeos/ai-controller-jobs:2024.10.x-dev". Manual copying may cause you other problems sooner or later
Re: [SOLVED] How to start index of importing items? (Elasticsearch)
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 24 Feb 2025, 12:57
ok, send this comand to server:
